Old 03-02-2011, 01:08 PM   #1
KVB
Parking brake levers
I am working on my brakes, 1965 C10, stock six lug axles. I need the parking brake levers that go on this truck. Any suggestions as to where I can get a kit, or the seperate parts. There is the left and righ levers, as well as a pivot pin with a c-clip.
I am in the Montreal, Quebec area.
Ken
KVB is offline   Reply With Quote
Old 03-02-2011, 02:08 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Parking brake levers
Your handle should be on the left of the column. I looked at LMC and didnt see anything.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-02-2011, 05:48 PM   #3
kieth
kieth's Avatar
Ken
Are you referring to the levers that mount on the frame ?
kieth is offline   Reply With Quote
Old 03-02-2011, 06:59 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
give areotruk63 a pm, i think he is in your area too...
I remember him doing a post like this too, then I think he came up with some part #'s
Old 03-02-2011, 08:48 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Here's the Aerotruk thread, it does include part numbers in post #9:
http://67-72chevytrucks.com/vboard/s...t=brake+levers
Old 03-04-2011, 01:34 PM   #6
KVB
I have gone to GM with the parts numbers listed by Aerotruck63, they are in stock, 22.00$ a piece, and they cannot tell me if they include the pivot pin and the c-clip. I just thought someone would have gone through this before and could guide me to the best solution.
Old 03-04-2011, 01:36 PM   #7
KVB
The levers I am looking for, are inside the brake drum. Where the end of the cable hooks up to.
Old 03-04-2011, 02:23 PM   #8
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
They don't come with the c clips from GM, they do have the pins. We ordered a box of 100 clips from Papco removed two then sent the box back. Ask Jim or Rob,Were bad! I`d give a call to Fastenal in your area and check to see if they sell them individually. You can order from GM as well but at what cost. Princess Auto should sell a kit, then what do you do with the rest. Dorman, Moog, dosen`t sell the levers we looked at all our suppliers, nada. Norm 514-695-5795
I`ve seen guys use a self locking nut and bolt to hold the lever on, not original but it works.
Old 03-04-2011, 06:47 PM   #9
maxwoof
Try these guys: http://www.obschevy.com/
They have them. Look in the brake section.
Spreaser bar can be had from LMC, or Dorman.
maxwoof is offline   Reply With Quote
Old 03-04-2011, 11:59 PM   #10
KVB
Aerotruk63 & maxwoof, thanks for the info and link. Seems like obsolete is the route to take. It comes as a kit and is less than the GM dealer.
Ken
