Old 03-02-2011, 04:40 PM   #1
2wd73blazer
Questions about NOS 1967 fenders
I have a nos 1967 fender. The guy I bought it from told me that one of the ways you can tell if a 67 fender is original is the 3 little triangles at the top of the fender at the front(see pics). Has anyone else heard of this? Also the fender I have doesnt have the bracket that bolts the fender to the cab up top. What do you do there??
2wd73blazer is offline   Reply With Quote
Old 03-02-2011, 05:38 PM   #2
chewychevy67
Re: Questions about NOS 1967 fenders
Every 67 oem fender has had the three triangles. not sure about the mounting tabs. maby remove the one from your existing fender and add it to this one?
chewychevy67 is offline   Reply With Quote
Old 03-02-2011, 05:59 PM   #3
2wd73blazer
That is what I was thinking. The 2 holes where the mounting tabs should be are threaded. I didnt know if they made one that bolted on instead.
Old 03-02-2011, 11:48 PM   #4
71 super
71 super's Avatar
That looks like the big truck fender, they do not have the brackets at top to mount like the 1/2 -1 ton trucks do.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 03-03-2011, 08:56 AM   #5
Big truck fenders bare no resemblance to 10-30 series what so ever. I can't say I know what's going on with your fender,though. I have never seen that on any fender. I have OEM '67 fenders and they are made like any other fender.
Old 03-03-2011, 10:45 AM   #6
2wd73blazer
I just bought a passenger side nos fender for a 67 off ebay. I havent received it yet but in the pics it looks like it doesnt have the brackets either. I will post pics of it when it arrives.
Old 03-03-2011, 11:56 AM   #7
Tim Christian
Tim Christian's Avatar
Not for a 1/2 ton. I hope you are doing a BIG truck?
Tim Christian is offline   Reply With Quote
Old 03-03-2011, 12:53 PM   #8
Do cowl & chassis fenders bolt up different?
Here's a medium duty truck:
Old 03-03-2011, 03:58 PM   #9
2wd73blazer
What big truck are they for? Does anyone have a way to look up the part numbers? They are 3886701 and 3886702.
Old 03-03-2011, 04:17 PM   #10
Dave
DND Trucks
I don't know for sure if the number on the fender 3886701 is actually a GM p/n. However, I looked up the GM p/n for a '67 LH and RH ... Ser. 10-30 (except FFC) is: 3898859 LH; 3898860 RH.
I don't have a big truck (Series 40-70) GM parts book or I'd look the number up. But, I suspect you may have a fender for that type of truck.
Dave is offline   Reply With Quote
Old 03-03-2011, 04:49 PM   #11
2wd73blazer
Here is a pic of a 1967 C-40. The fenders dont look anything like what I have.
Old 03-03-2011, 05:39 PM   #12
Dave
DND Trucks
I can't believe I didn't see this before but after looking real close, it does say FFC. You have a FFC (flat face cowl) fenders-- Which was for Canada and some Mexican export trucks. As these didn't have the same cowl configuration as domestic trucks, but everything else on the fender is the same.
So, like the other member said cut off the brackets from your other fenders and mig weld them on and call it good.
Old 03-03-2011, 05:47 PM   #13
2wd73blazer
Thanks for the info. Why in the world would they have different methods to attach fenders?
Old 11-14-2014, 10:42 PM   #14
EARNHARDT#3
EARNHARDT#3's Avatar
Old thread I know... Anyway I have a chance to buy a pair of these same fenders. I just want to verify that welding the bracket on will make them work on my '67 just fine.
EARNHARDT#3 is offline   Reply With Quote
