03-02-2011, 06:34 PM | #1 |
Power Brakes......Yes or No?
OK, I have installed a Comp Cams "Big Mutha Thumpr" cam in my 64. Since this cam is so big and requires a great deal of vacum, I now figure i have 3 options for my power brakes;
#1- Install a vacum canister (looks bad under the hood) #2- Install a vacum pump (expensive) #3- Loose the power booster (no power) So, if i choose option #3, how disappointed will i be running manual brake setup? BTW........The entire brake system is off an 86 Chevy donor truck. |
03-02-2011, 07:25 PM | #2 |
Re: Power Brakes......Yes or No?
Option #4
Hydro boost. I got mine off an Astro van (not installed yet). Runs off power steering pump. No vacuum connection. Here's a thread: http://67-72chevytrucks.com/vboard/s...ht=hydro+boost
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. Last edited by Slow Build; 03-02-2011 at 07:27 PM. |
03-02-2011, 08:19 PM | #3 |
Good idea. I will check it out. Thanks
03-02-2011, 08:36 PM | #4 |
x2 on the hydro boost.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
03-02-2011, 08:37 PM | #5 |
After reading that post, hydro is looking better and better.
