Old 03-02-2011, 06:54 PM   #1
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Question Cab support....
Can you guys tell me if these are the same thing?
The box section behind the rockers on both sides of my Truck are rotted out, and I came across these on Ebay are they replacements?
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 03-02-2011, 06:56 PM   #2
674x4ton
Re: Cab support....
Look the same to me
674x4ton is offline   Reply With Quote
Old 03-02-2011, 06:58 PM   #3
ebfabman
Re: Cab support....
Yes those are front cab supports. Many of the venders that support this board sell them. You may want to contact Wes at Classic Heartbeat.
ebfabman is offline   Reply With Quote
Old 03-02-2011, 07:05 PM   #4
'Mater
'Mater's Avatar
Re: Cab support....
Looks like the rusty parts are the front, the replacements are Rear. The good news is if the Fronts are that bad the Rears are not far behind so your will be able to use the parts you got.
'Mater is offline   Reply With Quote
Old 03-02-2011, 07:37 PM   #5
eightbanger
454 MAKES IT ROAR
Re: Cab support....
Yeah it does say "Rear" on the listing, my bad!
I'll hit Wes for them, there ae a few other bits I need from him.
Thanks guys for all the replies, much appreciated.
Nigel.
No more pain.
Old 03-02-2011, 08:18 PM   #6
steelscout
Words under my name
steelscout's Avatar
Re: Cab support....
Not to steal the thread, but are those bolt on and welded? Or just bolted on?
69 Chevy CST/10 "Project: Bloody Knuckles" my slow going project.
2010 VW Golf, daily driver
Wrench Rookie
steelscout is offline   Reply With Quote
Old 03-02-2011, 08:48 PM   #7
eightbanger
454 MAKES IT ROAR
Re: Cab support....
Both! when I saw the bolts I thought, this will be an easy bit of body work...no such luck
Nigel.
No more pain.
Old 03-02-2011, 08:52 PM   #8
DeputyDan
Re: Cab support....
Whats the best way to remove these? I took my tranny and engine out so I have really good access. I don't see any spot welds so whats the best removal procedure air chisel?
DeputyDan is offline   Reply With Quote
Old 03-02-2011, 09:03 PM   #9
steelscout
Words under my name
steelscout's Avatar
Re: Cab support....
Ugh... Appreciate the reply, I have one that's rotted out, one with a half dollar sized hole and the other two appear to be ok, since I don't weld I will most likely have to pay for that.
Wrench Rookie
Old 03-02-2011, 09:12 PM   #10
eightbanger
454 MAKES IT ROAR
Re: Cab support....
Air chisel if you got one....I'm gonna grind mine off, then anything the wheel can't reach I'll go at with hammer and chisel.
Nigel.
No more pain.
Old 03-02-2011, 11:42 PM   #11
60ratrod
yes, i do
60ratrod's Avatar
Re: Cab support....
man eightbanger, that mount is clean compaired to my driver's side mount. there's like no metal left between where its welded to the floor pan and part of it that's mounted to the rocker. its horrible. but i also have to replace the driver's floor pan so i'm just going to weld my replacement support straight on my replacement floor pan. i need to get on that one of these days....
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
