Old 03-02-2011, 09:30 PM   #1
383Chevy
[><]Sofa King Dirty 4x4[><]
383Chevy's Avatar
How can i improve a lil bit on gas mileage
I have a 383 stroker with dart heads single plain intake and a 600cfm holley 3.23 gears highway stuff, i get up go to the gas station get $10 worth wich is about 2.5 gallons of gas, go to school wich is barely 8 miles away come home dont go anywhere get up the next morning all my gas is gone whats the deal here? i have a locking cap so noones siphoning my gas idk what more to do specially with gas prices the way they are.
00' Chevy Silverado 1500 z71
33"s
3" lift
5-speed
Past trucks
85' Chevy C10 Step side
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
92' S10/Tahoe sbc swap
383Chevy is offline   Reply With Quote
Old 03-02-2011, 09:37 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: How can i improve a lil bit on gas mileage
Originally Posted by 383Chevy View Post
....go to the gas station get $10 worth wich is about 2.5 gallons of gas......
It's because you have "a 383 stroker with dart heads single plain intake". That single plane and those Dart heads are designed to flow fuel, not sip it. Great for grins, but not so much for MPG.
Best solution is to park it and buy a cheap small car or truck.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-02-2011, 09:44 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Ditto !
Or maybe slide a block of wood under the gas pedal ?
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-02-2011, 09:49 PM   #4
383Chevy
383Chevy's Avatar
Originally Posted by Restrorob View Post
Ditto !
I drive the speed limit even under to save gas lol and i thought about parking it but i like it but theres gotta be a way to get better we built a 388ci in a corvette and it got 16-17 mpg with aluminum heads
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 03-02-2011, 10:04 PM   #5
Restrorob
Restrorob's Avatar
Have you checked for any fuel leaks, Like the tank sending unit hoses ?
What tranny you run'n ?
BTW, I'm hotter in Fl too....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-02-2011, 10:07 PM   #6
383Chevy
383Chevy's Avatar
Havent checked for leaks but ive been wanting too just havent got the chance also running a th-350
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 03-02-2011, 10:16 PM   #7
lilpoindexter
lilpoindexter's Avatar
lilpoindexter is offline   Reply With Quote
Old 03-02-2011, 10:18 PM   #8
383Chevy
383Chevy's Avatar
Originally Posted by lilpoindexter View Post
Whats so funny? i didnt ask for any smartass remarks thanks though
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 03-02-2011, 10:21 PM   #9
pig rig
pig rig's Avatar
take a golf ball and throw it. then take a brick and throw it. witch one goes farther
golf ball made to cut through the air like a corvette
brick dosnt cut through the air like a SQUARE BODY truck
just saying your comparing apples to fire wood
horsepower and gas milage together is an oxymoron
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 03-02-2011, 10:23 PM   #10
383Chevy
383Chevy's Avatar
So im an oxymoron? figured id post here so i wouldnt get bashed but its starting to look like it thanks for the help NOT i guess i wont post here anymore
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 03-02-2011, 10:24 PM   #11
Restrorob
Restrorob's Avatar
I'd pull a couple spark plugs and see if their black from running too rich, If their not black start hunting for leaks. I just can't fathom that SB drinkin gas like that, My 502 LUVS it but still gets 13 mpg....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-02-2011, 10:25 PM   #12
383Chevy
383Chevy's Avatar
I will check that tomorrow im in the mixed of getting a GOOD air cleaner too, thanks you seem to be the only one helping
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 03-02-2011, 10:27 PM   #13
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
383, chill.
Your setup is not going to pull the best MPGs, these heavy trucks arent exactly aerodynamic either. Id triple check timing, maybe set carb. with vac guage and go easy on the pedel. Maybe think about OD trans in the future?
John
1999 Toyota Tacoma 4x4
Old 03-02-2011, 10:32 PM   #14
383Chevy
383Chevy's Avatar
Originally Posted by oldblue1968chevy View Post
383, chill.
I am chill but laughing at something thats not a laughing matter is stupid, im pretty easy on the pedal i dont speed or lead foot i dont have the money for that does the 700r4 only had OD or does the th-400 have it?
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 03-02-2011, 10:32 PM   #15
zackary027
zackary027's Avatar
no one means to be mean its just there's not much hope for our trucks with horse power like a 383 puts out. change the intake put on a quadrapuke on top of it if you dont have to demanding heads and cam, change out the gears in the rear end, but even then maby a maximum of 15 mpg
zackary027 is offline   Reply With Quote
Old 03-02-2011, 10:35 PM   #16
tucsonjwt
So, 16 miles divided by 2.5 gallons = 6.4 mpg - correct? The most accurate way to check fuel mileage is to fill up the tank, drive it a few days, fill up the tank (same pump, same level) and divide gallons used by miles driven. In my experience, a stock V8 pickup is good for 10 mpg city at best - less in winter with 10% alcohol in the gas. I lose about 1.5 mpg in the winter with my 454 C20. Check your fuel inlet nut at the carburetor- if gas leaks there it evaporates on the intake manifold so you never see it leak - might smell it though. I would not expect more than 8 mpg with your setup, unless you are on the highway with that 3:23 rear.
tucsonjwt is offline   Reply With Quote
Old 03-02-2011, 10:35 PM   #17
383Chevy
383Chevy's Avatar
I still think i have a good leak i was getting 14 with 4.11 gears a couple months ago its even cut to 2barrels instead of 4 its the damndest thing i cant figure this truck out i was getting almost 16mpg with 4.11s and 315 drag radials i put 33" a/t's and i went down to 14 then down to 10 then back up and back down switching back and forth from 2brl to 4brl, i know the filler hose has a small crack at the end so i spill a lil bit of gas out while pumping but its got to be evaporating or something from somewhere i already had a fuel inlet nut leak and i took care of that
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 03-02-2011, 10:39 PM   #18
Restrorob
Restrorob's Avatar
Just a side note; I drove my 74 as a DD for 8 yrs, Stock 350 2bbl turbo 350 and the BEST it would do is 10.5 mpg even after a carb rebuild and EVERYTHING in the ignition system new and fine tuned....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-02-2011, 10:40 PM   #19
383Chevy
383Chevy's Avatar
Wouldnt a manual 4 speed help with mpg? we just had a 85 suburban 3/4ton 350 with the 4 speed got close to 17 mpg's
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 03-02-2011, 10:53 PM   #20
mongoose
mongoose's Avatar
get a vaccum gauge and learn to keep it all the way to the right.. ='s best mileage for what you got...
you still running the 33's? i'd put the 4.1's back in... especially if you're not doing and highway.. ie cruising at 50 or w/e should make the engine run a lot easier.. thus use less fuel even though you may turn a couple hundred more rpm.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 03-02-2011, 10:55 PM   #21
383Chevy
383Chevy's Avatar
4.11's got stripped out so 3.23's were all i got but with the 4's it screamed like 2400 ish rpm im at 1600 rpms at 55
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 03-02-2011, 10:55 PM   #22
87 V20 Scottsdale
87 V20 Scottsdale's Avatar
What about trying a lower rear end gear, like 3.73. You said you were running 33 inch tires, with a 3.23 rear end. That would be similar to a stock tire turning a set of 2.73's. No matter how powerful an engine is, it will always take a little more effort to turn a taller set of gears.
The chart in this link may be able to better get my point across.
http://www.4lo.com/calc/geartable.htm
Yellow = better economy
Green = everday driving
Red = more power
Andrew
1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10
1988 C1500 Scottsdale 305, 700R4, 3.08
1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10
87 V20 Scottsdale is offline   Reply With Quote
Old 03-02-2011, 10:57 PM   #23
87 V20 Scottsdale
Mongoose beat me to the punch, 1600 RPM is lugging the motor.
Andrew
Old 03-02-2011, 10:58 PM   #24
383Chevy
383Chevy's Avatar
Red = more power
I may look for some 3.73's initially i thought they were 73's till igot them and counted and it came out 23's ill see if i can find them though thatd prolly help out a bit
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 03-02-2011, 11:00 PM   #25
cableguy0
You killed your mileage in the process of trying to find more. Switching to a 2bbl will almost always hurt gas mileage. Going to taller tires with a higher gear has you somewhere around the equivelant of a 2.73 gear. Your lugging your engine by having the rpms so low during cruise. Go back to the 4bbl and put some more gear in it. MId 2k rpms is where a small block likes to be. Lower rpms is not always better. If you were getting 14mpg with a 383 in a heavy truck you should have left it exactly how it was because that it real good mileage for one of these old pigs with the aerodynamics of a brick.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
