Old 03-02-2011, 11:47 PM   #1
russgt
russgt's Avatar
Aftermarket clutch linkage
Does anyone have experience with this type of linkage? I have been looking for replacement pivots for my Z-bar but have had no luck. While searching I stumbled on to this set up and it looks interesting. Any thoughts?http://cmc.speeddirect.com/itemdesc....%2D125&eq=&Tp=
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 03-03-2011, 08:43 AM   #2
ECU PIRATE
ECU PIRATE's Avatar
Re: Aftermarket clutch linkage
Brothers has the same thing in their catalog. swb85 on here is running there set up on his truck.
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 03-03-2011, 09:12 AM   #3
SeanPaintsFlames
SeanPaintsFlames's Avatar
Are you looking for the things the Z bar pivots on between the motor and frame? This won't replace that. It just replaces the clutch linkage and makes it adjustable.
That being said, those heims joints are only $5 or so at Ace Hardware. They're just tractor tie rod ends. I made linkage like that for my Cougar and a friends Mustang after a mechanic friend did it on my GMC for fun. It should cost you about $20 worth of heims joints, grade 8 bolts, threaded rod, and some round tubing. You can make it as adjustable as you want.
Threaded rod runs through tubing, weld on both ends. Heims joints on ends of threaded rod with lock nuts. Bolt through Heims joints into Z bar, bolt through other joint into clutch pedal, lock washers and nuts on the ends. Done.
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 03-03-2011, 09:19 AM   #4
bigblockrock
bigblockrock's Avatar
^X2^. I did this on my chevelle. Its cheap and you have all the adjustability in the world. No more binding and sloppy linkage.
bigblockrock is offline   Reply With Quote
Old 03-03-2011, 10:39 AM   #5
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Looks like a great idea but as mentioned that seems to be way too much money!
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 03-03-2011, 12:24 PM   #6
swb85
On a budget like Fred Sanford
swb85's Avatar
Wow, price went up on that stuff. I think I only paid ~50 bucks for mine a couple years ago. My old linkage was worn out and had lots of slop in it....this was a great upgrade.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 03-04-2011, 01:35 AM   #7
russgt
russgt's Avatar
I was more or less wondering if converting was worth the effort, sounds like its not a bad idea. As far as the pivots are concerned, I still havent found someone that sells them yet.
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 03-04-2011, 01:47 AM   #8
smashingchuck
Grainger
78 Build Thread
4Runner Build
Old 03-04-2011, 01:52 AM   #9
smashingchuck
or Fastenal
78 Build Thread
4Runner Build
Old 03-04-2011, 07:37 AM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Classic Parts sells both pivot balls you need. Cheap too.
Old 03-06-2011, 12:50 AM   #11
russgt
russgt's Avatar
thank you sir
70 stepside
76 blazer
86 Silverado
71 Nova SS
