Old 03-03-2011, 10:39 AM   #1
awbrown
Let's see some pictures of hot stovebolts!
This one is the one I talked about when I introduced myself to this forum.. It is a 261 bored and stroked to 303 .. Offset ground crank to 4.220 , bored to 3.905 (not recomended due to how close it is to the head gasket ) H beam rods and custom pistons....
awbrown is offline   Reply With Quote
Old 03-03-2011, 12:43 PM   #2
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Let's see some pictures of hot stovebolts!
Videos:
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-03-2011, 02:46 PM   #3
NCD1966
NCD1966's Avatar
292 with a nice cam
heres another one of my favorites
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 03-03-2011, 03:03 PM   #4
1Bad62Pro/Street
Originally Posted by NCD1966 View Post
292 with a nice cam
YouTube - Hot Rod 292 six cylinder
YouTube - Kirby Race Truck
Daaaaaaannnnnnnggggggg................
Ole' Kirby is hooking up good with that 292!
Old 03-03-2011, 03:36 PM   #5
Pop's C-10
Pop's C-10's Avatar
That is sweet music
Pop's C-10 is offline   Reply With Quote
Old 03-03-2011, 09:58 PM   #6
DLOE65
DLOE65's Avatar
Here's mine! 292 bored .30 over
DLOE65 is offline   Reply With Quote
Old 03-03-2011, 11:22 PM   #7
awbrown
I like the color!!!
Old 03-25-2011, 05:37 PM   #8
64_C10
DLOE65, That is sweet.
Can you help answer my post?
http://www.67-72chevytrucks.com/vboa...d.php?t=453772
Thanks alot.
64_C10 is offline   Reply With Quote
Old 03-25-2011, 05:59 PM   #9
DLOE65
DLOE65's Avatar
C10 your link isn't working, what questions do you have? Hopefully I can help.
Old 03-25-2011, 06:57 PM   #10
monolith
Zero Albedo
monolith's Avatar
Awbrown, may I get some details on that carb linkage on the 261? I just picked this up to put in my 66- the outboard carbs are blocked off- but at some point I'd like to remedy that, and in the meantime have the linkage set up even if the carbs aren't doing anything.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Old 03-25-2011, 07:34 PM   #11
64_C10
My 64 C10 has a remanufactured engine with F07I7N stamped on the block. The casting number is 3788406 (62-69) 230 I6. I haven't been able to determine from what year and model is from. Can you help?
Old 03-25-2011, 07:53 PM   #12
awbrown
@ Monolith ..
My buddy likes doing that kind of stuff, he spent 14 hours doing it !! I think if I was going to do it again I may use 3 seperate cables and merge them to a lokar pedal with a cable .. If it is a Offy manifold they sell the linkage , it simply hooks all 3 carbs together ... you could hook the end two together and run the center with a cable or the stock linkage..I have been told by one person that these carbs wont work turned 180 but I think that person had fuel problem ,I have yet to try this one because it is still at the upholsterers....
Old 03-25-2011, 07:55 PM   #13
DLOE65
DLOE65's Avatar
Aww I don't know anything about engine numbers, I found out mine on google. Just type in "230 straight six engine identification" try a few different titles, you will find it eventually.
Old 03-25-2011, 08:49 PM   #14
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
The blown 6's are SICK!!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-26-2011, 02:11 AM   #15
pulltilbroke
pulltilbroke's Avatar
6 thats in the 60
292 thats goin in the 67
Not a Stovebolt but still has 6 cylinders and makes more HP and torque than the other 2 combined.
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12
67 C-20,292,SM420,HO72
90 Dodge W250 Cummins,NV4500HD,205,D60/D80
93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70
pulltilbroke is offline   Reply With Quote
Old 03-27-2011, 09:31 PM   #16
Heater63
Heater63's Avatar
Well, since we got off of stovebolts and onto 292's, here's some of mine.
LP pistons, Schneider Cam, lump ports, big valves, roller tips, all ARP, balanced and hopefully bulletproof.
I had the original '63 valve cover chromed. The sea foam green block color will be the truck color too.
I'm welding up the exhaust now, then on to brackets to mount a Type II power steering pump, etc.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 03-27-2011, 09:44 PM   #17
awbrown
Nice job can't wait to see it all done !!! I have a soft spot for 6's...
Old 03-27-2011, 11:04 PM   #18
DLOE65
DLOE65's Avatar
Nice 292, what did you use for a gasket on langdons water heat plate?
