03-03-2011, 03:15 PM | #1 |
BigBlockBobby
making my inside panels
Worked on my 70 2wd, Made the the sides out of 1/4" cabinet facing 4x8 sheet is $28.00 . Also covered the floor with it, Got the vinyl from a local fabric shop..$ 40.00 for 2 yards which was plenty/ Made the top rail out of 1 x3 pine routered the edges and stapled the fabric to the back . used furniture leg dowels to attach with wing nuts underneath for quick removal. Installed new carpet from stockinteriors .com $ 275.00 for the 4 piece kit. Deliverd in about 4 days and fits good.
Bob Last edited by bobshotrodblazer; 03-03-2011 at 03:21 PM. Reason: add info |
03-03-2011, 06:34 PM | #2 |
Re: making my inside panels
Looks good!
1972 CST 4" Lift 33" Toyo MT's Kenwood Deck Rockford Fosgate 6x9's Rockford Fosgate Amp |
03-03-2011, 06:36 PM | #3 |
Well done. Looks pretty darn good.
03-03-2011, 06:54 PM | #4 |
needs more $$$
Very nice! I have a few questions since i bought some material a while back to do this as well:
1. Is there a reason you didn't go all the way back to the the tailgate with the panels? 2. Are they only held in with the chrome strip? 3. Can you explain the wood dowl/wing nut thing a little more? Are they wood wing nuts? I've never heard of this but sounds like a perfect option!
1970 2wd Blazer |
03-03-2011, 09:05 PM | #5 | |
BigBlockBobby
2. Chrome strip and pressure against the carpet. I was going to put in some screws but right now it works for me. 3. You can get these at home depot or a hardware store it's wood thread on one end and machine (1/4- 20) on the other they are about 2-3 inchs long
Bob |
03-03-2011, 11:09 PM | #6 |
Bob, That looks great!!! Those chrome strips cleaned up nice.
03-03-2011, 11:18 PM | #7 |
Rollin in my K5 toaster
Nice and clean.
03-03-2011, 11:45 PM | #8 |
Looks great ...i do have one question... A stipid one but gotta know...if I am correct, you laid the floor carpet onto the 1/4 cabniet wood.. How come you just didnt lay deadner pad then the carpet? Im going to cross this bridge someday and thought i would ask
Posted via Mobile Device |
03-04-2011, 09:11 AM | #9 | |
BigBlockBobby
Bob |
03-04-2011, 09:12 AM | #10 |
BigBlockBobby
fine steel wool works miracles
Bob |
03-04-2011, 11:08 AM | #11 |
VA72C10
very nice work! I especially like the rail caps!!!
Looking for a 67-72 swb or blazer project in or around VA. |
03-04-2011, 01:31 PM | #12 |
Looks great! I like the idea of the flat floor. Question - where did you get the chrome strip? Polished is #0000 steel wool?
03-04-2011, 04:31 PM | #13 |
BigBlockBobby
The chrome strips are factory CST pieces . Bought on here from board member. Looking for another set for my buddy's K5
Bob |
03-04-2011, 08:11 PM | #14 |
very clean i like it. im about to build some panels myself, probably out of fiberglass with some shape to it, actually kinda surprised i havent seen it more often.
im thinking about doing something like in this picture with a lot less curvature though. maybe something that is more outward at the bottom of the panel and has just one 6 inch speaker on each side of the wheel well where it curves out and to an angle like the panel in the picture just not nearly as much. to get the shape all you do is build a frame out of wood and staple a stretchy fabric over it then glass it, something i would enjoy doing. |
03-07-2011, 01:11 PM | #15 | |
03-09-2011, 10:22 AM | #16 |
GEARHEAD
Looks great. I like the rail caps, good idea.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
