Old 03-03-2011, 04:33 PM   #1
StingRay
StingRay's Avatar
GM paint code 507 light blue
Dad had a 69 GMC when I was a kid and it was my first vehicle. It was light blue and I've always wanted to do truck in that color for nostalgia's sake. I believe it was 507 light blue and would be greatful if somebody that has a truck in this color with the code on the spid could post a picture for me so I can verify that I'm thinking of the right color.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 03-03-2011, 04:51 PM   #2
burkeens
Re: GM paint code 507 light blue
here
burkeens is offline   Reply With Quote
Old 03-03-2011, 05:35 PM   #3
StingRay
StingRay's Avatar
Many thanks that is definitely the color
Canada
Old 03-03-2011, 07:46 PM   #4
68gmsee
Active Member
68gmsee's Avatar
My 68 used to be this color and probably will go back to it.
Here's more pics I picked up from here.
68gmsee is offline   Reply With Quote
Old 03-03-2011, 07:53 PM   #5
68gmsee
Active Member
68gmsee's Avatar
There are suttle differences to the color but I attribute this to either the mixing process or scanner/cameras. Not sure.
This is the color of mine on the inside. I rattle canned mine a slightly darker color on the outside but will probably go back to the stock baby blue color when I have it painted professionally.
Old 03-03-2011, 08:10 PM   #6
skunkwerx
skunkwerx's Avatar
that was the original color of my truck,and i like it alot,so i painted my wheels that color
Skunkwerx
skunkwerx is offline   Reply With Quote
Old 03-03-2011, 10:23 PM   #7
feller
feller's Avatar
i am digging the custom cup holder there how is it atached??
feller is offline   Reply With Quote
Old 03-03-2011, 11:27 PM   #8
68gmsee
Active Member
68gmsee's Avatar
I am using two brackets made out of aluminum and bent to the proper angle so the cup holder is level. The brackets use the same holes that the heater control asm uses under the dash. I used slightly longer bolts for more bite.
Old 03-04-2011, 02:55 AM   #9
lil hoodlum
lil hoodlum's Avatar
GM light blue # 507
These are three different paints GM used and corresponding number
Dupont 4537-L (Acrylic Lacquer)
Rinshed-Mason A-1686 (Acrylic Lacquer)
Ditzler DQE-12846 (Enamel)
Keith
lil hoodlum is offline   Reply With Quote
Old 03-04-2011, 11:01 AM   #10
68gmsee
Active Member
68gmsee's Avatar
^ might be the reason there's different shades of it.
The color definitely is different. My daughter gave me her 94 Ranger that is the Lapis Blue color. Similar to the 507 color. I've only seen 2 of these rangers besides mine in this area and it's easy to find in the parking lot.
Old 03-04-2011, 11:31 AM   #11
burkeens
another view
(color looks a little off due to cell phone pic and lack of natural light where photo was taken)
