Best 4 link setup for a 1950 panel
I have a 1950 chevy short panel. I am going to bag it and want it to lay out. I know the frames are fairly narrow. Was wondering if a triangulated 4 link or wishbone or... Would be best. I am also thinking about using tapered sleeved bags or if there is any other recommendations.
Re: Best 4 link setup for a 1950 panel
Doing a triangulated four link on that narrow frame might be hard to get the upper links triangulated enough. I would do a 4-bar and a panhard, with the sleeve bags behind the axle.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
![]() Join Date: Jul 2010
check out our FatBar kits. the 47-54 frames taper out, so the frmae mounts need to take this into concideration.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
