Old 03-03-2011, 11:16 PM   #1
fuzzy23
fuzzy23's Avatar
Suggestions on Dash
What would you use to remove all this crap on dash? Thank You in advance.
1972 K1500 Longbed 350 w/3 on tree.
1976 Chevy Nova 350 auto
1972 C10 (donor)
fuzzy23 is offline   Reply With Quote
Old 03-03-2011, 11:33 PM   #2
grs
Re: Suggestions on Dash
Adhesive remover might work.
grs is offline   Reply With Quote
Old 03-03-2011, 11:37 PM   #3
jc67cst
jc67cst's Avatar
they make some stuff called oops. may have to soak it a time or two.
1972 C10 SWB Cheyenne- Tubbed, 4link, 6.0, etc.
1970 C10 SWB - Work in slow progress
2013 GMC 2500 Denali - Deleted
jc67cst is offline   Reply With Quote
Old 03-03-2011, 11:44 PM   #4
Southcity
Southcity's Avatar
If you have a can of WD40 around try this before buying anything. Work in small sections, spray some WD40 on, let it soak in a little and use a rag and rub, keep spraying as you go along, it might break it down enough to where it will come off.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 03-03-2011, 11:45 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Your dash pad will cover it up, right?
3M makes an adhesive and woodgrain remover. It comes in a quart can. I'm sure there's some acetone in the mixture, so be sure you have plenty of ventilation. Also, wear some gloves that will protect your hands.
When you put your new dash pad on it, it should be covered up.
Member Nr. 2770
Old 03-04-2011, 12:09 AM   #6
fuzzy23
fuzzy23's Avatar
Thanks for all the suggestions hopefully I get some time to work on it this weekend.
I know everyone likes pics.
1972 C10 (donor)
Old 03-04-2011, 12:44 AM   #7
MistaGavin
MistaGavin's Avatar
"Goo Gone" For sure. I use it for almost everything. Old stickers, window tint residue, ect.
You're not old, it IS loud!
1970 CST-10 BB 400
MistaGavin is offline   Reply With Quote
Old 03-04-2011, 01:40 AM   #8
BlazinC5
BlazinC5's Avatar
WD40 works great on stuff like that usualy. And it smells kinda pretty to me...
71 2wd Blazer
My build, Restarted
05 Buell firebolt
94 1500 Z71
No rice for me,,, I'm full
BlazinC5 is offline   Reply With Quote
Old 03-04-2011, 02:13 AM   #9
cjohnson6772
cjohnson6772's Avatar
+1 for Goo Gone. Used it for decals on the side of dump trucks and tractor trailers. No residue and pretty cheap.
cjohnson6772 is offline   Reply With Quote
Old 03-04-2011, 06:14 AM   #10
steelscout
Words under my name
steelscout's Avatar
Good stuff that ^, and also Spit fire, this is primarily a industrial stain and spot remover but also works great on hard to remove sticky crap, spray>soak for a minute>wipe away. you can find it in a Janitorial supplies store. And to add, it has never ruined anything I have used it on to include removing 100mph tape residue from Army gear...
69 Chevy CST/10 "Project: Bloody Knuckles" my slow going project.
2010 VW Golf, daily driver
Wrench Rookie
steelscout is offline   Reply With Quote
Old 03-04-2011, 06:23 AM   #11
Jeffs70
Jeffs70's Avatar
WD40 Does work great, I agree with this the only problem with WD40 is if you plan on Painting any surface after using WD40 you might want to clean with something else that will wear off the WD40 and allow paint to stick.
Jeffs70 is offline   Reply With Quote
Old 03-04-2011, 08:45 AM   #12
Jessechop
Contractors Solv-It is what we use here at work. You can usually get it at hardware stores. Smells like oranges and works great. Spray it on, let it sit, wipe it off
Jessechop is offline   Reply With Quote
Old 03-04-2011, 09:16 AM   #13
gkesseru
gkesseru's Avatar
NEVER use WD-40 anywhere you intend to paint. Just one hidden drop will ruin the paint job. My painter won't even let one can be anywhere in the shop.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 03-04-2011, 09:27 AM   #14
68GenIII
Is is getting repainted? If so sand it off or wipe it with laquer thinner. That should do the trick.
68 lwb to swb Cummins swap in the works. I promise it will be cool someday.
68GenIII is offline   Reply With Quote
Old 03-04-2011, 09:59 AM   #15
Shane
Shane's Avatar
acetone or lacquer thinner ON A RAG ... do NOT pour it directly on the dash ...
Shane is offline   Reply With Quote
Old 03-04-2011, 10:07 AM   #16
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The above suggestions will probably work.I would suggest trying them first and if they don't you can clean it well with a fine steel wool and then use rubbing compound and wax to bring on the shine.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-05-2011, 09:34 PM   #17
fuzzy23
fuzzy23's Avatar
Thank you to all for the suggestions. I just ended up leaving most of it I just used some purple power and scotch brite and then installed new dash pad.
1972 C10 (donor)
Old 03-05-2011, 11:40 PM   #18
67chevy1series
67chevy1series's Avatar
looks good!
67chevy1series is offline   Reply With Quote
