Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-03-2011, 11:32 PM   #1
shawnt
shawnt's Avatar
Spool axle packages
I have a 10 bolt 8.5" in my 85 swb. Anyone know any spool and axle packages for 30 spline that fix this
Shawn
85 SWB
7.39 @ 93
Best so far with 0 tuning
Lesson in life: Never fry bacon naked!
shawnt is offline   Reply With Quote
Old 03-04-2011, 01:20 AM   #2
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Re: Spool axle packages
www.moserengineering.com/
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 03-04-2011, 09:09 PM   #3
djracer
djracer's Avatar
Originally Posted by 68 C-10 KID View Post
Agreed.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-09-2011, 12:19 AM   #4
85_prairieboy
85_prairieboy's Avatar
I got mine from Moser. They even pressed the c-clip eliminators on to the axles
85 GMC toy Lowered, newer box swap, 350 .060 over with AFR 195s, forged pistons, TCI TH350
1.83 60' 13.14 @ 100 on motor
1.49 60' 11.52 @ 116 w/150 shot
1952 Chevy truck project
1980 Z28 Camaro
1967 Camaro drag car 10.60@126
85_prairieboy is offline   Reply With Quote
Old 03-09-2011, 07:43 PM   #5
shawnt
shawnt's Avatar
I knew about strange and mark williams and moser. I was told you could take a 30 spline posi for the 10 bolts and use 12 bolt axles in them... anyone heard of this?
Shawn
85 SWB
7.39 @ 93
Old 03-13-2011, 06:17 AM   #6
C-10 simplex
i think so; Will try to find the link.
C-10 simplex is offline   Reply With Quote
Old 03-14-2011, 02:50 PM   #7
C-10 simplex
Yes, i checked and it is possible. This is according to Randy's and they really know their stuff concerning rear ends.
12 bolt axle's c-clip button thickness is .312 inches, while the 10 bolt c-clip button thickness is .25 inches. So, if the 12 bolts buttons are machined/grinded down it will work. You would need a 30 spline carrier of course. Would a posi change the position of the axles to each other compared to an open rear?
(how does this work, as i'm not real familiar with how axles are put into the assembly, but am learning); i'm not sure if the grinding would be nessesary if you use a spool---b/c you'd be using c-clip eliminators?
8.5 10 bolt 30 spline axles slide in with no modifications.
