Old 03-04-2011, 03:50 AM   #1
Jeffs70
Jeffs70's Avatar
Shaving Rain Gutters/Drip Rails
I Know I have seen quit a few people asking how to Shave the Rain Gutters/Drip Rails.
So I figured while I do mine I will take Pictures and give more info on how I am going to go about doing this. Hope this info does go to good use for someone.
First of all You will need these Required Tools:
Safety Glasses
Welder
Grinder
Grinding Sandpaper Wheel
Sheet Metal
Sheet Metal Cutters
Always nice to have a Magnet
Sawzall or Angle Die Grinder with Cutting Wheel Or use a Cutting Wheel on your Angle Grinder.
Grinder
Sheet Metal Cutters, Magnet, and Sheet Metal
Sawzall
Name:  Sandpaper GrindingDisc.jpg
Step #1.
If You have your Windshield and Rubber Seal still in your Truck you should Protect it/Cover it before starting this project Unless your replacing them like I am before this truck is finished.
Jeffs70 is offline   Reply With Quote
Old 03-04-2011, 04:01 AM   #2
Jeffs70
Jeffs70's Avatar
Re: Shaving Rain Gutters/Drip Rails
Step #2
Cut the Rain Gutter/Drip Rail from the top down around an Inch in Length at a Time.
Cutting to much can cause the roof to flex and move out of its original place.
Be careful not to cut to close to the roof till you get a visual of what your working with and how you want it to look. some people have different tastes how they wish theirs to look so mine may not be the look you desire.
Step #3
After Cutting the Rain Gutter/Drip Rail off take your grinder with your Grinding Sandpaper Wheel (Disc) if needing to grind alot of the rail still off to get closer to the roof and grind away till your happy.
Step #4
Cut some Small pieces of Sheet metal to fit in the bare area where needed (Good Place to use your Magnet to hold the small Sheet Metal Pieces in Place) and Tack weld them in. Other Helpful Tips and Info in Step #5
Notice the Big Gap with no Sheet Metal in the Picture - This is where you will Add Sheet Metal If going the way I am with my Shaved style
Step #5
Weld each side of where you have cut off the Rain Gutter/Drip Rail to keep it secure and not allow the roof to move or flex at all.
Remember do not weld to much in one area. you want to just tack weld it up (one touch at a time in each spot) if you heat the metal up to much you will warp the sheet metal. each time you Tack weld it move to the next spot far enough away. Knowing when to quit and take a break inbetween is a good thing. (See Picture 1)
Step #6
Sand down the welds smoothly with your Grinding Sandpaper Wheel(Disc). Do not use a Hard Grinding Disc also Do not sand to much of the Sheet Metal. Dont allow the Sheet Metal to turn Blue. That is what Causes it to Warp
Old 03-04-2011, 04:05 AM   #3
Jeffs70
Jeffs70's Avatar
Here is the Passenger Side View of the Drip Rail with Primer
Old 03-04-2011, 05:29 AM   #4
steelscout
Words under my name
steelscout's Avatar
That is awesome work! I always wondered why Chevy used seam sealer instead of just welding it?? I hope this makes it ino the FAQ
69 Chevy CST/10 "Project: Bloody Knuckles" my slow going project.
2010 VW Golf, daily driver
Wrench Rookie
steelscout is offline   Reply With Quote
Old 03-04-2011, 05:30 AM   #5
Jeffs70
Jeffs70's Avatar
Thank you steelscout, I never could understand why they used the seams like this either. I know these trucks leak often but man they are ugly lmao
Old 03-04-2011, 05:33 AM   #6
steelscout
Words under my name
steelscout's Avatar
Agreed, good welds =no leak
Wrench Rookie
Old 03-04-2011, 05:57 AM   #7
OARNGESI
OARNGESI's Avatar
Looks good are you fixing the window frame I didn't realize how much the drip rails hide as fAr as door gaps untill it was too late
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-04-2011, 06:02 AM   #8
Jeffs70
Jeffs70's Avatar
Thanks OARNGESI, I will add some sheet metal along the bottom of the roof of the door gap and weld it along there to create a nice gap around the same diameter as behind the door and in front of the door. yeah I noticed that on the passenger side it gave me a headache till I finished it lol.
I will provide pictures of that here in the next day or two for the door gaps.
Old 03-04-2011, 10:01 AM   #9
Shane
Shane's Avatar
you think they leaked WITH drip rails ...
Shane is offline   Reply With Quote
Old 03-04-2011, 10:23 AM   #10
Jeffs70
Jeffs70's Avatar
Thanks for your comment Shane.
Old 03-04-2011, 02:06 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
The front of the roof, when you look at it from the side, is taller than the rear of the roof. Joe McPherson eliminated his drip rails and changed the contour of the roof on the truck. He also changed the way the glass is installed, going to a glue-in installation. He used '88-98 wheel openings to get rid of the round openings of the '67-72. It took Custom Classic Trucks, or Classic Trucks magazine 2 issues to cover all of the changes to this truck. Then, when Squeeg was through building it, it was driven from San Francisco, to Miami, FL.
Member Nr. 2770
Old 03-04-2011, 02:44 PM   #12
coggonobrien
any idea what it takes to convert to glue in glass??????
coggonobrien is offline   Reply With Quote
Old 03-04-2011, 04:23 PM   #13
OARNGESI
OARNGESI's Avatar
Have you thought of shaving the rear roof Seem
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 03-04-2011, 04:24 PM   #14
OARNGESI
OARNGESI's Avatar
I think opp makes a kit
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 03-04-2011, 04:40 PM   #15
Jeffs70
Jeffs70's Avatar
Yeah that thing is off and odd ball in my book also. but I dont know if I will be digging into that any time soon.
Old 03-04-2011, 05:18 PM   #16
Jeffs70
Jeffs70's Avatar
ChevLoRay Thats a nice truck.
Old 03-04-2011, 10:49 PM   #17
(joey)
(joey)'s Avatar
another little tip if the wind shield is removed, just fit it back in place every once in a while to make sure wind shield frame is not warping.because i didnt and the lack of metal in my windshield frame and front inner roof panel ,by the time i was finished i was way off.you can see what i mean in my build thread
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline   Reply With Quote
Old 03-04-2011, 11:04 PM   #18
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I just saved the pic. I wish I had access to the file, on-line. It is even more impressive when you see the chassis. The exhaust system is tucked up inside the frame rails and fed through holes cut into crossmembers. It's all polished stainless, as I recall. After looking at the articles, and then reading that it had been driven to Florida from San Francisco, I was amazed. That cross-country trip was the shakedown cruise. I'm doing good to want to try driving around the block!
Member Nr. 2770
