Old 03-04-2011, 03:34 PM   #1
duwem
duwem's Avatar
Starter Solenoid Shimming for Gears?
I have read you need to adjust the solenoid postion on these old starters so the starter gear travels to the right positions in relation to the ring gear.
Can someone elaborate on this? My solenoid is the type that bolts to the top of the starter with 4 bolts, sloted holes in the bracket. Some use 2 bolts to the starter head and use shims instead of slots.
Something about manually activating the plunger and a paperclip?
duwem is offline   Reply With Quote
Old 03-04-2011, 04:37 PM   #2
OrrieG
OrrieG's Avatar
Re: Starter Solenoid Shimming for Gears?
I do not think you need to shim 235 cylinders, only V-8 block mounted starters.
OrrieG is offline   Reply With Quote
Old 03-04-2011, 08:46 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Connect a battery ground to the starter. Connect a wire from the battery to the solenoid energiser wire. Not the large pole. It will activate the plunger. You want the starter bolted in when you do this. Slide the solenoid forward or backward to make sure the gear engages the flywheel without going to far and slamming the starter housing nose or not far enough and grinding the teeth off. With the flywheel cover off you will be able to look up into the flywheel hosuing and see where the engagment is on the flywheel.
These old starters had a habbit of knocking off the nose of the starter when not adjusted properly.
dwcsr is offline   Reply With Quote
Old 03-05-2011, 12:41 AM   #4
mr48chev
mr48chev's Avatar
Your profile doesn't show what vehicle or engine you have or are working on so we really need to know that before someone can give you the correct advice rather than guessing what you are working on. I think Dwcrs is close to the right answer but there should be a method where the starter doesn't spin the engine to check this.
On that starter by shimming the starter drive I would believe that they mean for a person to place the correct thickness shim washer on the armature shaft between the drive and the snout. That would restrict the drive from going too far into the ring gear teeth.
mr48chev is online now   Reply With Quote
Old 03-05-2011, 01:21 AM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
I should have stated that you DO NOT have the starter battery cable connected when you do this so the starter will not spin, it just pops out the bendix drive, Sorry.
Old 03-05-2011, 02:01 PM   #6
duwem
duwem's Avatar
Engine is a 235 appears to be a 58-62 vintage.
Starter solenoid style shown here.
http://67-72chevytrucks.com/vboard/s...d.php?t=447342
I got it all mounted, wired up and running, but it doesn't engage every time. Ring gear teeth looked pretty rounded off.
