Old 03-04-2011, 08:03 PM   #1
Hardesty454
Hardesty454's Avatar
Holly Red Fuel pump
Im moving things around on my 70 (fuel lines) and want to move the pump as well. It is currently mounted on the fender wall and I want to move it somewhere it wont be seen. Does anyone have any ideas where the best location would be? Should it be closer to the tank (currently origonal) or the carb?
Also, pictures of mount set up is appreciated.
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 03-04-2011, 09:58 PM   #2
ItsRandy
ItsRandy's Avatar
Re: Holly Red Fuel pump
Electric pump? As close to the gas tank as you can get.
ItsRandy is offline   Reply With Quote
Old 03-04-2011, 10:41 PM   #3
mr48chev
mr48chev's Avatar
Yes, Electric pumps are designed to push rather than pull and the closer to the fuel tank the better. With any rig with enough engine to require a Holley Red pump you need every advantage you can get,
Old 03-04-2011, 10:53 PM   #4
Hardesty454
Thats what I was thinking...
Ok.
Can I run it along the frame rail (which is real close to my exhaust)?
I don't feel as if that would be the safest place for it.
Rob
Old 03-04-2011, 11:28 PM   #5
colin_havens
colin_havens's Avatar
I run a Holley red pump, and have it mounted to the frame below the in cab gas tank. No issues, and my truck lays frame. I do however have it mounted to the outside of the framerail, and my exhaust is ran inside the frame rails. Don't expect it to be quiet as a church mouse though, those pumps are loud no matter where you put them.
colin_havens is offline   Reply With Quote
Old 03-05-2011, 12:03 AM   #6
mmmBoost
Mine was mounted on the frame about a foot from the back of the frame rail about 9in from my fuel cell. Worked amazing, just be sure to put some kind of rubber insulator between it and the frame rail otherwise it resonates the humming sound thru the truck
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline   Reply With Quote
Old 03-05-2011, 06:06 PM   #7
Hardesty454
awesome... (mounted and wired it last night, just got to try it out today.
Rob
