Old 03-04-2011, 08:09 PM   #1
protrash64
Resistance is Futile
protrash64's Avatar
Distributor Question
I know the engine guys will know this stuff, but I'm asking here first. I'm swapping dizzy's to get HEI and noticed the ring on the shaft of the old 283 dizzy. It appears to be about the level of the lifter valley. In the pic the tape measure is pointing at the ring. The HEI does not have this feature.
Is this a problem? It appears to not have any function other than oil restriction? Don't know........chime in if you know. Thanx guys.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-04-2011, 08:37 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Distributor Question
I`m running the same HEI, no problem, been in for two years...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-04-2011, 08:42 PM   #3
maynardtruckin
maynardtruckin's Avatar
no problems swapping the two! just a casting difference!
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
Old 03-04-2011, 11:11 PM   #4
protrash64
protrash64's Avatar
Thanx guys.....already have it installed!! I will be updating the build thread.
