03-04-2011, 09:42 PM | #1 |
Let's see pics of fuel cells
Starting my build and would like to see diff fuel cells people are using. Show them off guys
Posted via Mobile Device |
03-05-2011, 12:32 AM | #2 |
Sofa King Crazy!!
Re: Let's see pics of fuel cells
This is the Summit 16 gallon.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
03-05-2011, 01:35 AM | #3 |
Hand Crafted C-10
03-05-2011, 02:49 AM | #4 |
Slick67 that's a nice set up. Did it come with the attachment to add a hose
03-05-2011, 10:54 AM | #5 |
Dave's not here, man
Here's mine. I am still trying to decide on a filler for it.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
03-05-2011, 12:21 PM | #6 |
Nice fuel cell but can I have some of that DEW and a SMOKE
03-05-2011, 12:58 PM | #7 |
Sofa King Crazy!!
It is custom. A better way is to leave the cap on in the center and make a new hole close to the rear left side, that makes it easier to pipe to the side of the bed.
03-05-2011, 11:21 PM | #8 |
Never got mine installed. http://67-72chevytrucks.com/vboard/s...d.php?t=430864
03-06-2011, 02:08 PM | #9 |
Is anyone running something different other than a Fuel Cell Guy tank or a blazer tank swap? Maybe a spun aluminum mooneyes tank? The reason I ask is I cannont run a typical tank swap like most do and put it where the spare tire went, due to being bagged and laying frame (I would drag a hole in the tank on NO TIME) and all my airride tanks and compressors are mounted there under the stock bed floor. Im lookign for ideas that will work, but still look good.
03-06-2011, 02:31 PM | #10 |
Sounds like it will not work for you but her's mine.
03-06-2011, 05:06 PM | #11 |
03-06-2011, 06:40 PM | #12 |
That's right, it's Copper!!
Here's mine, CPP fuel cell!
Tom: 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! |
