Old 03-04-2011, 11:06 PM   #1
Kidd-7
Kidd-7's Avatar
Rear springs compressed, advice?
This was obviously somebody's attempt to lower the rear end. Should I remove these? If so any tricks? Thanks.
Kidd-7 is offline   Reply With Quote
Old 03-04-2011, 11:26 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Rear springs compressed, advice?
Kidd, movin' ya to suspension to the gurus.
ETsC10 is offline   Reply With Quote
Old 03-04-2011, 11:31 PM   #3
LEEVON
Moderator
LEEVON's Avatar
I would just take a cut-off wheel to that contraption. Protect your eyes and hands and you should be fine, the spring itself is restrained and not fully compressed.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 03-04-2011, 11:36 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Definitely remove them.
If you still want the lowered ride height,... add a quality set of drop springs.
While your at it,... trim those u-bolts.
Keith
Convert to disc brakes.
Old 03-04-2011, 11:51 PM   #5
Kidd-7
Kidd-7's Avatar
Trim the U-bolts??? I always wondered why they were sooo long, but just figured thats the way it is... Think those u-bolts were replaced at some point?
Old 03-04-2011, 11:59 PM   #6
lolife99
lolife99's Avatar
Yes.
Trim off any part of the u-bolt that extends past the nut.
Keith
Old 03-05-2011, 01:00 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
actually, someone was trying to LIFT the rear. Those 3 center coils are supposed to be almost on top of heach other, like they are on the oposite side of the coil.
Remove the spreaders, leave them there, you'll never notice them untill you look under again. In theory they stress the spring where they are spread apart, but theory isn't reality.
Old 03-05-2011, 11:44 AM   #8
Kidd-7
Kidd-7's Avatar
So you're saying it dosen't matter if they stay or they go...
Why are the coils supposed to be on top of each other? I would think having space between them would allow for better smoother compression when bouncing on bumpy roads. Its physics and I'm no major, but any insight?
Old 03-05-2011, 12:22 PM   #9
daved
those look like spring clamps to me.....clamping together lowers the truck.....to lift it they made the spring spacer that u turned inbetween the coils with a 1/2 breaker bar...anyways remove the clamps (i would unbolt them) and buy some lowering blocks if u want it to be a little lower......goes in between the axle pad and trailing arm....it will use up the rest of the threads on the bolts and u will still have a decent ride..
daved is offline   Reply With Quote
Old 03-05-2011, 01:42 PM   #10
Wild83C10
Wild83C10's Avatar
Yes.
You should leave some threads after the nut, don't trim them flush.
If you plan on getting some lowering blocks those U-bolts would work well.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-05-2011, 02:18 PM   #11
Kidd-7
Kidd-7's Avatar
Any recomndations on good lowering blocks? I may just add some...
71 C-10 - 307 - 3 on tree
01 Ford Explorer 5.0 v8
96 Mercury Cougar v8
79 Trans Am 403 Olds
Old 03-05-2011, 02:35 PM   #12
lolife99
lolife99's Avatar
You can purchase new u-bolts and lowering blocks here:
http://www.stockcarproducts.com/trkarm1.htm
Many suspension vendors also sell them.
CPP, Performance Online, etc.
Keith
Old 03-05-2011, 03:51 PM   #13
cdowns
cdowns's Avatar
tryin to wack those things off with a cutoff wheel could cause you bodily harm and bloodshed
two of the proper sized wrenches and some pbblaster wood b my choice
better safe than sorry
back in the 60's-70's those type of thing were sold to lower coil springs//sold at pepboys jcwhitney strauss stores i thing they even had them in the sears catalogue
Old 03-05-2011, 04:47 PM   #14
Kidd-7
Kidd-7's Avatar
The PB and wrenches sounds like a better option to me, not keen on grinding stuff that potentialls under tension. I've seen things similar to these that are used to compress the springs on struts, I'd never trust them though.
Old 08-24-2011, 10:53 PM   #15
Kidd-7
Kidd-7's Avatar
Well I finally removed them; nuts came off easy for the most part. Pneumatic impact did its job. 2 of the threaded rods were bent and had to resort to my sawzall; that made quick work of it. thanks for the input.
