Old 03-05-2011, 10:42 AM   #1
otsenre
otsenre's Avatar
3/4 ton possi rear diff
68 3/4 ton rear differential, must be picked up, its a maxi tract R axle, need it gone asap need to make room 200 Name:  IMG_1572.JPG
otsenre is offline   Reply With Quote
Old 03-05-2011, 10:56 AM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: 3/4 ton possi rear diff
Good price for a coil spring rear. The metal tag on the left side of the cover should tell you the gears. If it is from the big block truck, it could be 3:54 which should be desireable. Good luck with the sale.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-05-2011, 01:09 PM   #3
DieselEater
DieselEater's Avatar
Wow, Thats a coil Dana 60.....I thought only the GMC leaf trucks used that rear.
That would be a good axle to narrow for racing...Instead of using a 9".
A...........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 03-05-2011, 06:44 PM   #4
rich67
rich67's Avatar
rite price. too far. always!
rich67 is offline   Reply With Quote
Old 03-06-2011, 11:18 AM   #5
I wish I could swing by and pick it up. if I did I believe i would stay in CO.
Old 03-06-2011, 01:11 PM   #6
scott72
scott72's Avatar
Think I'd have any issues putting that in a 72 2wd?
I would like to put a posi rear end in my truck, have the cash, and am about 5-6 hours away from you.
Any problems with it?
scott72 is offline   Reply With Quote
Old 03-06-2011, 01:36 PM   #7
otsenre
otsenre's Avatar
It was a running, driving truck, I dont know why you could not put it in a 72, this is a 3/4 ton 8 lug, what do you have?
Old 03-06-2011, 02:05 PM   #8
scott72
scott72's Avatar
1/2 ton C10 with 3/4 ton springs
12 bolt 5 lug
Old 03-06-2011, 02:15 PM   #9
otsenre
otsenre's Avatar
3/4 ton 12 bolt
Should fit, maybe some of the pros will chime in!!
Old 03-06-2011, 09:39 PM   #10
scott72
scott72's Avatar
bump. =D
Old 03-07-2011, 11:55 PM   #11
dmack91
dmack91's Avatar
If you are asking if the entire axle assembly would swap in, it should, but you would have 6 bolt rims in front and 8 in the rear.
Don't know about just swapping out the internals. I read that some are interchangeable, but you would need to know how to properly set up a differential, which isn't for the faint of heart.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 03-10-2011, 08:40 PM   #12
otsenre
otsenre's Avatar
Ttt
