03-05-2011, 11:23 AM | #1 |
new with a 62
Hey guys, new to the forum. I just picked up a pretty solid 62. Its just primer white right now. It has a 350 and a turbo 400 trans. I was able to drive it home but quickly found out it had bigger tranny issues than I had thought. I was told it just needed a rear seal, but now once it warms up it poors fluid out the front seal so I found another trans to throw in it. Anyway heres a pic of it..sorry its the only one I got right now.
I had a few questions too. How low can I go with a static drop and no c notch? Also the timing is off. It has a 350 with an hei distributor. I can't turn the ditributor anymore because the vacuum advance hits the firewall on the passenger side. Do I just need to lift the distributor out and turn it counter clockwise one tooth and drop it back in? Do I make sure the rotor is pointing in the same direction or does it need to turn with the distributor? |
03-05-2011, 11:30 AM | #2 |
Re: new with a 62
Great looking 62, as far as the dist just pull the dist and rotate the engine to TDC #1 and drop the dist back in , the coil on the cap should be paralell to the firewall more or less, and #1 should be the front rh position on the cap if you were standing in front of the truck
Good Luck !! QUOTE=62allenhead;4531450]Hey guys, new to the forum. I just picked up a pretty solid 62. Its just primer white right now. It has a 350 and a turbo 400 trans. I was able to drive it home but quickly found out it had bigger tranny issues than I had thought. I was told it just needed a rear seal, but now once it warms up it poors fluid out the front seal so I found another trans to throw in it. Anyway heres a pic of it..sorry its the only one I got right now. I had a few questions too. How low can I go with a static drop and no c notch? Also the timing is off. It has a 350 with an hei distributor. I can't turn the ditributor anymore because the vacuum advance hits the firewall on the passenger side. Do I just need to lift the distributor out and turn it counter clockwise one tooth and drop it back in? Do I make sure the rotor is pointing in the same direction or does it need to turn with the distributor?[/QUOTE] |
03-06-2011, 12:56 AM | #3 |
60-66 Nut
Re: new with a 62
Welcome to the forum
Yes that does look like a solid '62....post up some more pics when you get a chance.
03-06-2011, 01:21 AM | #4 |
Senior Enthusiast
Re: new with a 62
Nice looking truck. Welcome to the forum.
03-06-2011, 11:08 AM | #5 |
One day...
Re: new with a 62
Good looking truck! Looks like a 456 grill huh?
03-06-2011, 11:21 AM | #6 |
Re: new with a 62
Thanks for the compliments. Last night I got the other tranny back in. The new trans was out of a 3/4 ton, so it had a bolt in yoke. I thought I was going to have to swap the tail shaft extension, but I lucked out and the slip yoke seemed to work. What I didn't luck out on was the trans mount seems to have a different thread pitch than the other trans. Has anyone else had this problem? If my threads are messed up would it be a problem if i just through bolted it? Also the turbo 400 has an electric kick down which apparently wasn't hooked up on the last trans. What do I need to do to hook that properly. Along with the kick down problem the speedometer cable hook up is a little different. The new trans has a square slot that the cable sits in, my cable has a long skinny metal end rather than short and square. Does anyone know what cable I need? Thanks again.
03-06-2011, 11:25 AM | #7 |
Re: new with a 62
03-06-2011, 05:39 PM | #8 |
Re: new with a 62
Glad to see another 62 on the forum !!! Truck looks good !! Congrats and Welcome form Oregon !!
03-06-2011, 08:19 PM | #9 |
Re: new with a 62
great to see another Michigander snag a great truck .. looking forward to seeing more pictures....
03-06-2011, 09:12 PM | #10 | |
Re: new with a 62
03-06-2011, 09:59 PM | #11 | ||
Re: new with a 62
Thanks for the heads up. |
03-06-2011, 11:43 PM | #12 |
"Where were you in '62?"
Re: new with a 62
Welcome to the forum Bud.
Glad to see more '62's on here. Posted via Mobile Device
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
03-19-2011, 11:13 AM | #13 |
Re: new with a 62
So I got rid of the 3/4 ton turbo 400 and picked up a 700r4. I know I have to fab up a new crossmember and get the driveshaft cut, but what do I do with the 4 prong plug on the side of the tranny? On the driver side rear of the tranny is a 4 prong plug, what do I need to wire this up?
03-20-2011, 01:03 AM | #14 | |
60-66 Nut
Re: new with a 62
You can use any truck auto trans crossmember from '63-'87 with the 700R4. You'll just have to move it back some and drill new holes. As for hooking up the trans, that plug is for the torque converter lock up. This really needs to be wired up and connected for proper operation and longer trans life. Another thing to be aware of on the 700R4's is the TV cable setup. Some will call it a kick down cable....it is not. The proper setup of the TV cable is very, very important on the 700R4's. If it is not done correctly, you will surely burn up that trans in a hurry. The best place for the TV kit as well as info on adjustment is http://www.bowtieoverdrives.com
You can also go to the 'Engine and Drivetrain' section of thos forum and do a search for '700R4' and or 'TV cable' and you will find many threads on the subject. Quote:
03-20-2011, 06:59 AM | #15 |
Re: new with a 62
Welcome! Great truck you got. It's got very nice potential and will be alot of fun.
06-08-2011, 06:24 PM | #16 |
Re: new with a 62
Well I finally got my trans. all buttoned up and I painted the wheels and threw on some wide whites. Sorry for the bad pic, we are going to hit a car show this weekend so hopefully I will have some better pics after that. I also put an old fender flag pole, from my vw days, where the antenna used to be...I still need to wire it up though.
06-08-2011, 07:37 PM | #17 |
Re: new with a 62
What car show ???
06-08-2011, 07:48 PM | #18 |
Re: new with a 62
Nothing special, just our local moose lodge show. Probably more beer drinking than car showing
06-09-2011, 12:34 AM | #19 |
Re: new with a 62
nice truck
06-10-2011, 02:32 PM | #20 |
Re: new with a 62
did your 700r4 have a exciter for the speedo signal or did it have a manual drive for your speedo ? I had to change from the electronic to the manual drive. It was easy after getting the parts. Kieth
Here is a link to pictures of my 700r4 and changing it out for a manual speedo cable. I got the parts from some place in Louisiana..........cannot remember......getting old.... http://kieth.smugmug.com/Trucks/66-G...13173619_4TK8C Last edited by kieth; 06-10-2011 at 02:41 PM. |
06-10-2011, 02:49 PM | #21 |
Re: new with a 62
Great looking truck
06-11-2011, 08:50 PM | #22 |
Re: new with a 62
very nice truck. great pick up (pun inteded)... do you have any pics of your vw's?
06-13-2011, 09:59 PM | #23 |
Re: new with a 62
heres a few pics of my old 67'. My wife has been on me to get another one so hopefully I can make that happen. |
06-13-2011, 10:00 PM | #24 | |
Re: new with a 62
