Old 03-05-2011, 12:27 PM   #1
daytonagp4
Shift linkage ?
I have a 83 4x4 with a 5.3 and a turbo 400 trans. My problem is when i installed my shift linkage 1st and 2nd gear are kind sticky. When I pull the gear shifter all the way down you and tell it gets into a bind. I adjusted the linkage but still no luck. Anybody else have this problem?
daytonagp4 is offline   Reply With Quote
Old 03-05-2011, 01:41 PM   #2
67C10BUB
67C10BUB's Avatar
Re: Shift linkage ?
I used the Kugel shift linkage and have the same problem. I wondered if the Ididit cable conversion kit would work better.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 03-05-2011, 02:49 PM   #3
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: Shift linkage ?
Did you install it in park or in neutral? It works much better to work from the neutral position. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 03-05-2011, 08:15 PM   #4
daytonagp4
Re: Shift linkage ?
I did in the park position....ill try switchin it tonight see what happens. Thanks
Old 03-10-2011, 03:03 PM   #5
daytonagp4
Re: Shift linkage ?
Did it in neutral.....still the same. i guess it's okay, not like i use 1st.
Old 03-10-2011, 06:28 PM   #6
67C10BUB
67C10BUB's Avatar
Re: Shift linkage ?
That's what I figured.
67 5.3L Build
