Old 03-05-2011, 02:49 PM   #1
Chris H
72 C30 Trailer Queen
Chris H's Avatar
Doug Nash overdrive unit for TH400
I have had this one sitting on the shelf for a while, bought a Gear Vendors and no need to keep them both...
Doug Nash Engineering Dual Range Auxiliary Transmission, bolts on your TH400 transmission instead of the tailshaft housing. Gives a .75 to 1 overdrive ratio. Electrically shifted like a 2 speed truck rear end, and can stay in either direct or overdrive. Commonly used on RVs, motorhomes, bigger trucks. Probably not well suited for hot-rod gear splitting, but pretty handy for the right applications. USGear bought out Doug Nash, very similar to the Dual Range.
Your 4.10 rear becomes a 3.08 in overdrive, 4.57 to 3.42, or 5.13 to 3.85. Keep your deep gear for off the line grunt, then shift to overdrive at highway speed to lower your RPM, maybe even save some gas in the process? Or leave it in overdrive when unloaded. Or...
All manuals and electric controls are included.
$900 plus shipping (less than $75 in the US48 I would guess).
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 03-05-2011, 09:42 PM   #2
qksilver
Re: Doug Nash overdrive unit for TH400
man.........temptation, very sweet.
A thought, total with shipping to 28387 business address...........pay pal?
pm me, i tend to forget things.
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 03-06-2011, 11:11 AM   #3
I wish it bolted to the tailshaft. Then,it probably would work on my M22. Bump for you^^
Old 03-07-2011, 09:04 AM   #4
Chris H
Chris H's Avatar
I know there was a version of this overdrive that operated as a stand alone or divorced type box. I think it was just a yoke input/housing for the front side.
Probably more trouble than it is worth, but a good excuse to top this ad!
Here is a picture I borrowed from a completed sale on ebay to give an idea on size:
Chris H
72 C30 133"
69 C10 short fleet
71 ElCamino
2006 K1500 RCSB
Old 03-07-2011, 02:08 PM   #5
va72longhorn
va72longhorn's Avatar
Chris, are you suppose to be able to use the original drive shaft since it takes the place of the tail? It looks a little longer. Just what I need on my C30 longhorn, though. I had actually been looking to change the 4:56 gears out, but this may be a little nicer set up. Gotta check the funds though.
va72longhorn is offline   Reply With Quote
Old 03-07-2011, 04:03 PM   #6
Chris H
Chris H's Avatar
You will need to modify/change the drifeshaft. The book says: "Establish new driveshaft dimensions (GM is 12 5/8" shorter ... FOMCO 1' 1/2") . If the vehicle has extremely short front half, it maybe more appropriate to use a new one piece shaft."
PM me your email if you would like me to send the scanned install manual.
4:56 with an overdrive would work real nice!
I will take paypal, so you could pay with your credit card
Chris
Chris H
72 C30 133"
69 C10 short fleet
71 ElCamino
2006 K1500 RCSB
Old 03-07-2011, 05:13 PM   #7
va72longhorn
pm'ed
How does the "switch" usually set up? Manually on the dash? Defenitely interested, especially after you call and talk the other half into it. I'll stand in the corner and listen....
Old 03-07-2011, 05:57 PM   #8
Chris H
Chris H's Avatar
Basically an on/off button that attaches to the gear shift lever.
Chris H
72 C30 133"
69 C10 short fleet
71 ElCamino
2006 K1500 RCSB
Old 03-07-2011, 06:06 PM   #9
va72longhorn
I knew a guy who had something similar, years ago, that had it hook up to another dimmer switch on the floor. I thought it was the coolest thing. I'll study the book tonight and see how much more it may cost me past the price of it. I hate to get into cutting and balancing the driveshaft. Im assuming you never had it on your 133" wheelbase (same as mine)? Anyway, put me in line for it, and see what my cost would be getting it to the porch. I can have it shipped to a business in 20166 if its any cheaper. Thanks
Old 03-07-2011, 08:07 PM   #10
junkyardjohn
junkyardjohn's Avatar
THATS ABOUT 1/3 THE PRICE OF A GEAR VENDORS UNIT. AT $4 A GALLON IT WONT TAKE THAT THING LONG TO PAY FOR ITSELF. A NO-DOUBT BARGAIN. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 03-08-2011, 11:03 AM   #11
junkyardjohn
Ttt for a bargain john
junkyardjohn
DON'T RENT U-HAUL
Old 03-08-2011, 11:13 AM   #12
fattyarbuckle
sweet!
Wish I could swing it but....
good luck with sale.
fattyarbuckle is offline   Reply With Quote
Old 03-10-2011, 02:12 PM   #13
Chris H
Chris H's Avatar
Still available until someone posts "SOLD" on this thread...
Chris H
72 C30 133"
69 C10 short fleet
71 ElCamino
2006 K1500 RCSB
Old 03-14-2011, 12:44 PM   #14
'78RV
Mark it SOLD......Going in a 1978 P-32 based RV behind a 454/TH400 combo....
The adventure begins.....
'78RV is offline   Reply With Quote
Old 03-14-2011, 01:16 PM   #15
junkyardjohn
Saweeeeet!!!! Bus. John
junkyardjohn
DON'T RENT U-HAUL
Old 03-14-2011, 04:24 PM   #16
'78RV
Thanks....it's my favorite toy. We carry two bikes & two 50cc Suzuki's on a single wheel swivel trailer plus two inflatable kayaks in storage bay...just a rolling collection of R&R toys.....Hoping Chris' OD is going to quiet things down a little at 60mph. At 24', I've got the same drivetrain & gearing as units that go to 36', so I shouldn't be pushing the OD or the TH400 too hard......
http://i283.photobucket.com/albums/kk304/leeschiek/DSC_0810-1.jpg[/IMG]
Old 03-14-2011, 05:12 PM   #17
junkyardjohn
It ought to be a great match. At almost $4 a dogone gallon, it ought to payoff immedeately. Thats an awful nice looking setup you've got there. I can see why it's your favorite toy. I'd much rather have a classic looking setup like your's than any new one I've seen. Niiiiice. John
junkyardjohn
DON'T RENT U-HAUL
Old 09-18-2012, 11:43 AM   #18
MTWayne
Hi, I have one of these units in my truck, there is no wiring though, is there a way that '78RV or anyone else could send me or e-mail me a scanned copy of the manual so I can figure out how to wire it? Any help is much appreciated!
Thanks,
Wayne
MTWayne is offline   Reply With Quote
Old 09-19-2012, 08:10 AM   #19
I never see '78RV on here. I think these are his only 2 posts. Have you tried contacting Doug Nash?
Old 09-19-2012, 09:23 AM   #20
Chris H
Chris H's Avatar
PM me with your email address if you would like a copy of the installation manual and the wiring manual.
I have them as .pdf but too big to attach here.
I did talk to 78RV after installation, and he seemed very pleased with its function.
You can read about his installation here:
http://www.barthmobile.com/eve/forum...267#2543922267
Chris H
72 C30 133"
69 C10 short fleet
71 ElCamino
2006 K1500 RCSB
Old 09-19-2012, 09:40 AM   #21
'78RV
'78RV here.......the overdrive manual is waiting for you in several places out there in cyberspace....here's one of them:
http://www.bangshift.com/forum/showt...ained.../page4
FWIW-some observations after a season's use:
1. Unit has performed great for me...I was sold a solid unit.
2. Weakest link is all the wiring, mainly for the OEM shifter - the electro-mechanical relay was undependable and trouble-prone.
3. My solution was to remove ALL of it....clip the wires of the two gray elipitcal plugs on the case and toss out shifter button, relay and all associated wiring. All it does is send signals to shifter - they do nothing regarding the actual shift change. You only need TWO wires to OD, one on each terminal of slide switch.
4. Replace all that with a truck style floor mounted dimmer switch. Keyed power goes to the center post, one wire from one leg goes to one terminal on slide-switch on passenger side of case, other wire goes from other leg to other terminal on slide switch. Now you just tap dimmer switch and switch motor compresses spring, ready for shifting when you unload the driveline torque.
5. When you figure which one is hot in OD, scab in a peanut LED light and you've got visual status of OD mode.
6. Electrical wear parts are shift motor and slide switch on case. I got new replacement motor over the counter at NAPA and switches are readily available.
7. Remember, shift motor doesn't shift anything...it merely preloads a spring that stays compressed until you unload driveline, then spring slides the gears. Shifting from normal to OD produces a noticeable CLUNK.....shifting from OD to normal produces a light CLINK...just the nature of the beast I guess.
Let me know if you need part #'s & sources for motor & switch. Hope this helps.....
