Old 05-17-2002, 09:04 AM   #1
ballentinesr@aol.com
Post anti sway bars
I have a 78 Cheyenne 1/2 ton 2wd. Am wondering about the effectivness of after market anti sway bars. Also an inexpensive source for these. Am trying to eliminate body roll to some extent. Any ideas? Thanks alot.
ballentinesr@aol.com is offline   Reply With Quote
Old 05-19-2002, 12:39 PM   #2
monypit
monypit's Avatar
Post
You might consider changing ou the springs to a progressive rate performance spring and adding a factory sway bar from a junkyard. The progressive springs will still have a nice ride but as they compress they get stiffer so you don't have as much body roll in the corners.
1973/1997 Blazer/Tahoe (it just doesn't know that it is a '73)
monypit is offline   Reply With Quote
Old 05-28-2002, 03:18 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
a 3/4 ton or 1 ton front bar wil make a huge difference alone, i owuld go for that first, find one under a junk 3/4 or 1 ton truck 64-87
good luck
Fast68Chevy is offline   Reply With Quote
Old 05-28-2002, 03:31 PM   #4
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
I agree with the others. but also do not forget poly bushings, they can make a world of difference themselves. Aftermarket bars are all pretty good from what i know but they're notmuch different (except performance ones) than the stockers. i agree go find a nice one in a yard and buy some poly bushings. 30 bucks for a set of poly bushings at my local 4x4 shop . good luck
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 05-30-2002, 01:02 PM   #5
yoeddie
Thumbs up sway bar
i just put one on my 83 , talk about nice! but i should have looked around a friend just picked one up from the junk yard for 20$ i'm going down today and see if i cant find one that will work on the rear of my truck
83,67,60,and53 chevy pickups
yoeddie is offline   Reply With Quote
Old 06-05-2002, 07:21 AM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Sway bars do work. On lowered truck they can work against you too! I have trouble with big bumps and big pot holes. The front springs are shot but they will be replaced. I'm rebuilding the entire front end.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 06-10-2002, 11:22 AM   #7
Low69CST
You should never use front springs to eliminate body roll. Some of the aftermarket bars like Addco are junk, or atleast the ones I got from my 69. If I were you I'd either get a 1-1/4" factory bar or buy a stock car style bar with splined ends and draft that on to your truck.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-11-2002, 01:39 AM   #8
littlebubba
Swaybars
You might check under some Suburbans. I am considering this swap too. Have to take some measurements for the rear bar yet. I have been told to look at newer 454SS pickup rearbar, and possibly the Tahoes or S10 Extremes. Would have to fab up the frame mounts though. Keep us posted if you find anything.
littlebubba is offline   Reply With Quote
