Need a little help please!
Hello men, having a confusing little issue with the truck today, need some experts input. Started truck up this morning no problem, let her warm up for a bit, and went to take off... killed the motor...no biggie, BUT when I went to restart got a few weak whirrr, whirrr, whirrr sounds from starter, but no start! Came back a few hours later and truck started like it was brand new! Battery strong, alternator fine(per my tester) what could have caused this? No temp gauge so I dont know how hot it was running, thermostat prob? Thanks for any help in advance!
1967 GMC 3/4 ton Fleetside 350 ci Chevy I'd rather do it myself and spend the extra 500 dollars |
Active Member
![]() Join Date: Jul 2007
Re: Need a little help please!
If you checked the alternator output and it was putting out at least 13.5 or more volts to the batter then it could be a starter solenoid or starter drive. You can probably get the whole starter complete for just a little more at Auto Zone.
choke sticking on?
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!! |
Choke seems fine.. truck just didnt want to start while warm..
It's all in the timing
What kind of alt. are you running,interal or external?
The Dude Abides. ---------------------- I aint sayin, I'm just sayin. |
sounds like the starter solenoid http://www.rockauto.com/catalog/moreinfo.php?pk=42690 is weak or dry and it will not engage the starter drive http://www.rockauto.com/catalog/moreinfo.php?pk=42360;)
Trueman |
#7 | |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Headers? If so they are death to the starter without a shield of some sort.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Cold it turns over strong, hot it struggles to turn over at all. Seems heat related. Ill check starter solenoid tomorrow, may be the ticket...
The Older Generation
Probably Starter Heat Soak from the exhaust. Only shows up when the exhaust gets the starter hot... LockDoc
Old Skool Club
![]() Join Date: Jun 2001
My truck didn't have any starting problems until I changed carbs. The new Edelbrock Q-Jet was a lot leaner running than the Edelbrock 1405 I took off of it. I have headers, too. I had to add the heat shield to the starter, but it solved the problem.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
I had a similar problem when I replaced a Holley 1850 on my small block with an Edelbrock 1406 carb. It would start just fine cold, but if I had driven for 15 to 20 miles then turned it off it would do exactly as described... like it was straining to turn over.
The starter was a new reman AC Delco hi-torque with heat sheild and wrap with matching solenoid. It started giving me "hot start" problems when I changed to the Edelbrock carb. After numerous calls to Edelbrock tech, I determined that my carb would drip raw fuel down onto the intake floor after turning off a hot engine. It would also stink up my garage with a raw fuel smell. I never really figured out exactly why it did this, but I figured it was a needle and seat problem. I replaced the needles and seats, but still no better. I changed back to my old grungy Holley and the problem magically went away. NoNeck
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. Last edited by NoNeck; 03-07-2011 at 01:18 PM. |
#13 |
Alright all, I finally sucked it up and bought a new starter from NAPA. Installed in truck and replaced battery wires as well. Believe I put the thing in correctly, but after all is said and done truck wont even turn over now. I rechecked all connections, still no start... now Im a little irritated and need some help on where to go next with this thing!
#14 |
Moderator
![]() Join Date: May 2007
It might need to be shimmed.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#15 |
Take it back and have them test the starter, might have sold you sa bad one.
1970 GMC truck ![]() 1988 Harley 1200 Sportster ![]() |
#16 |
Active Member
Yeah, it's possible you got a bad one but before you go through all of the trouble of removing it, recheck all of the wiring to make absolutely sure it's right.
If you still have the coil here's a good wiring diagram: http://67-72chevytrucks.com/vboard/s...d.php?t=251165 |
#17 |
You need to be a little more specific. Do you mean it won't turn over or it turns over but won't start. Does the solenoid click when you turn the key to start? If you got the Yellow and Purple wires switched around it wouldn't do anything. LockDoc
#18 |
Yeah Doc, it is absolutely dead, no noise whatsoever. The heavy bastard fell while I was taking the old one out, and may have tugged the wire from the ignition switch, now that I think of it...as I had forgotten to loosen it prior to removal... better check..
#19 | |||
"I ain't nobody, dork."
Now back to the OP... sounds like you might have pulled that wire by accident when the starter fell. I would check it all the way back to the harness. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#20 | |
![]() Quote:
