A/C ducting help..
I have a 72' c10 that used to have a/c... I have used an a/c delete box and blower, and have the first part that goes inside to the fire wall . Which also houses he heater core.... i am looking for pictures of the ducting for the interior. or if some one could list what ducts i would need to use to complete the ducting. Any help is apperceated..
Thank you, |
member #16
![]() Join Date: Dec 1999
Re: A/C ducting help..
Dont know if this will help, but here are all of the parts to choose from.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=118 .
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Thanks john..this is spot on...one question on that page 118..the one section that is not in gray....does that mean it is not available ?
Posted via Mobile Device |
Just a heads up to shop around on some of these parts as there is quite a lot of price difference in the various parts from LMC/ClassicPart/ThruckandCarShop.
Also, I ordered the AC/Defrost/Heater hoses (#16) from LMC. They are the type of hose you get on a shop vac and not very flexible. Trying to get the hoses installed and routed passed the wiper/radio/ignition was an absolute nightmare, these was just not enough room. I ended up leaving out the hose to the drivers side of the center vent. You may want to shout out to the board to find out if anyone has a better alternative. the originals I have seen in the junk yards although in bad condition, seemed a lot more flexible and could compress down a bit in the tight areas. I'm sure someone must have a better alternative to the plastic ones - just my opinion.
![]() ![]() ----------------------------------- { 1972 Chevrolet C-10 Fleetside, 350 V8, 5.7L. } ----------------------------------- |
