03-05-2011, 06:35 PM | #1 |
Roadtrip!
Brackets and pulley I.D help.
Going through some boxes of parts and can't figure some of these out.
Any help is appreciated. Group 1. These were marked big block. I think the top may be a small block a/c bracket? (3876222) The 6 could be an 8 Second, a smog adjuster? Not for A/C i am pretty sure. You tell me on the last 2... More coming...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
03-05-2011, 06:38 PM | #2 |
Roadtrip!
Re: Brackets and pulley I.D help.
Group 1 of pullies.
top, 3939002 AH next, 3932402 DU 3, 351680 AA 4, 3995648 AG The blue one has no info i can see. More coming.
03-05-2011, 06:44 PM | #3 |
Roadtrip!
Last 2 groups:
The top 3 groove only has LT stamped on it The next is 3996631 AO And the alternator bracket as not as wide as most. Not for a long pump small block. Last pic i know are small block, but looking for application. 3755820 BC And the double is 3744043. If someone with the correct books wants to take the time to look up these part numbered parts and I.D. them, i would gladly paypal $5 for your time. (little incentive) Thanks for any help. Eric
03-05-2011, 06:55 PM | #4 |
Roadtrip!
Ahhh, forgot the last pics i guess...
03-05-2011, 08:05 PM | #5 |
'Burban Legend
Educated guesses.
1 sbc AC 2 6 alt 3 OLD 8 alt 4 sbc smog pump 5 bbc long water pump alt pretty sure on all Bueller, anybody? hehe
'67 Chevy Iron City Beer Truck (9ft step) '67 Chevy Panel Truck 467 '68 Short Fleet 305v6 '68 McLaren Ramp Truck '68/'68/'70/'71 Burbs 292/366/402/454 '69 C-30 dump '71 C-50 dump and church bus '71 4x4 454 '72 Blazer (w/pop-up camper) $15 x-hooks '66 Chevy II 194/Weber '68 El Camino" 305v6 '69 Skylark 455 Buick '70 Chevelle 427 '71 Cutlass W-31 '71 GTO 400 2x2 "The 51" Chopped '51 Chevy (409) my first car OK Toad, we'll take 'em all... John Milner |
03-06-2011, 12:41 AM | #6 |
Member #1049
I'll give this a shot...Post #1 Group #1.. Small block lower AC bracket.. #2 and #3.. Smog pump mounting bracket and adjuster W/O AC.. (not sure if SB or BB without measuring bolt hole spacing) #4.. mid-late 70's long water pump AC bracket..
Post #2.. pulley #1.. not positive looks like SB short water pump with AC #2.. long water pump small block .. #3 and #4.. later model long water pump with PS.. Are you sure the number is 3995648 AG? and not 3995646 AG? if so.. short water pump with AC.. Post #3.. 3 groove pulley.. no clue.. same on next pulley.. the upper alternator is late 70's to early 80's long water pump small block. Here's a site to give you one app of the last two pulley.. (I am sure there are several more applications to each number) http://www.camaros.org/pdf/pulleys-PN-2007-02-01.pdf |
03-06-2011, 01:13 AM | #7 |
Roadtrip!
OK, we made some headway here. I think the second bracket in the first post i pulled off a 396 with a smog pump, but have nothing to compare it to.
So none of the pullies appear to be big block? These were mixed in with 3 BB crank pullies, so i was hoping i had some sets here. The site you posted didn't agree with my computer. I appreciate all the help so far and i will double check the number in question... Eric
