Old 03-05-2011, 07:18 PM   #1
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Are cowl panels being repro'd?
I see that fire walls are available but was wondering if the piece just above that is available? This piece goes behind the fenders and runs up across the top. (not the outer cowl that you see but the metal just under that)
Thanks,
Bob
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 03-05-2011, 07:59 PM   #2
biggestjohn
Re: Are cowl panels being repro'd?
http://www.lmctruck.com/icatalog/cb/t.aspx?Page=22
#4
biggestjohn is offline   Reply With Quote
Old 03-05-2011, 08:08 PM   #3
bobs409
bobs409's Avatar
Yikes! $249 dollars. Not sure I can justify spending that much but thanks for the link!
Bob
Old 03-06-2011, 01:50 AM   #4
$279 for the outer??? They are everywhere used in great condition for 1/10 that much. That piece takes a lot less to make than the inner. Makes me wonder about the quality of the inner.
Old 03-06-2011, 06:56 AM   #5
GMCPaul
We have the inner cowl panels available for $195.00ea part#5724081, they can be found on the following page of our web site
http://www.gmcpauls.com/Patch_Panels.htm
Heres a couple pictures of this part
Paul @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 03-06-2011, 11:10 AM   #6
72cheyenneman
Here's some pictures of the cowl being changed on my Cheyenne 10. I bought this from LMC and believe it or not, the fit was good for being an aftermarket piece. Couldn't believe my eyes how good it fit.
72cheyenneman is offline   Reply With Quote
Old 03-06-2011, 11:14 AM   #7
bcutt
bcutt's Avatar
I got mine from Southern KY Classics www.sokyclassics.com . $195 and it fit great.
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see."
- Thomas Jefferson
72 C10 SWB "Work in Progress"
bcutt is offline   Reply With Quote
Old 03-07-2011, 08:21 AM   #8
72cheyenneman
What do you all think a shop would charge to change this cowl panel out? The truck was at the shop, front cap off, then we discovered that the cowl should be changed. This is what was done: 1) Cowl cut off; 2) Sand blasted under cowl; 3) Some pinholes welded under cowl; 4) New cowl installed and primed with epoxy primer. Anybody want to chime in with an estimated cost, not including the cost of the new cowl? Keep in mind this truck is in restoration at a reputable shop because I'm no paint and body or sheetmetal man.
Old 03-07-2011, 08:26 AM   #9
cam.man67
cam.man67's Avatar
That must be nice, cuz their tailgates sure don't fit worth anything.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 03-07-2011, 09:32 AM   #10
ffk
ffk's Avatar
hey i might be cutting up a 68..it has a good cowl ( has some rust by the vent locations)..ill know in 2 weeks..im getting a different cab,so ill have no use for this on(the roof is in bad shape..
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604)
ffk is offline   Reply With Quote
Old 03-07-2011, 07:37 PM   #11
bcutt
bcutt's Avatar
Not sure but I would be curious to know, $500??
- Thomas Jefferson
