Old 03-05-2011, 11:32 PM   #1
leftybass209
leftybass209's Avatar
Front drum brake help!
I just purchased a 69 c10 shortbed, and the front passenger wheel had a horrible grinding sound coming from it. Well, tearing it apart today, i found NO outter wheel bearing. To the question, I can't find any exploded view of a front drum brake wheel bearing assembly. Can anyone tell me the order and names of the parts, assuming it's a bare spindle with backing plate and drum brake hardware already attached? like from the backing plate, up to the front castle nut. Any help would be greatly appreciated! Thank you!
leftybass209 is offline   Reply With Quote
Old 03-06-2011, 05:20 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Front drum brake help!
Would tearing apart the drivers side help you answer your question?
I recommend at least looking at it to verify it's OK.
Sounds like it's time for a disc brake upgrade,...
Keith
Convert to disc brakes.
Old 03-06-2011, 09:52 PM   #3
leftybass209
I hear you about the disc upgrade, but i'm not going to do that for a while. Because I have so much that would need to be done, convert to 5 lug, new wheels and tires, suspension kit, blah blah! I did tear the other side apart, but the problem is I don't know what the parts are called really, so it's making it hard to find the replacement parts. Thanks for the reply though! Love your truck, BTW.
Old 03-08-2011, 11:01 AM   #4
daved
order goes like this....grease seal, inner bearing, inner bearing race (pressed in hub), hub, outer bearing race (pressed in hub), outer bearing, slotted washer,castle nut. if the outer bearing was gone most likely you will need a hub as well and possibly a spindle...you can get the part numbers off the back side of drivers bearings
daved is offline   Reply With Quote
Old 03-08-2011, 11:43 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by leftybass209 View Post
I hear you about the disc upgrade, but i'm not going to do that for a while....
[QUOTE=daved;4538469..... if the outer bearing was gone most likely you will need a hub as well and possibly a spindle...[/QUOTE]If one side needs rebuilt the other side should be done too. If you factor the price of a complete rebuild plus the probability of needing a hub and spindle, you have a pretty costly rebuild.
Unless you are one of those that never plan to convert to disc brakes, now is the most logical time to do it. Invest in the future, don't put a patch on the past.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
