Embrace the Redneck
Pumpkin on fire!
Long rant - here goes.
Well. I took the Beast out for a long trip today. He don't get many so I thought it would be a great bonding time. Well 190 miles round trip and he made it 170 of them on his own and had to be towed the last 20. Was having fun doing 80MPH on the free way and the whining that's normal was getting louder and louder coming from the gear box so though, "Oh crud. Here we go again with the tranny issues!" Well get to the 190 mile marker on Missouri's I-70 east bound and the whining turned into a on-off-on jerking then BANG!!!!!! and sparks come flying out the rear of the truck. I'm thinking the drive shaft broke and fell down. Trow it in neutral and get off the road quick. Jump out to look down to see a nice amber flicker on the ground coming from the rear end. Look under and ![]() I had a 1L of Coke with me and had barely sipped from it and so I grab it and start to splash it on the rear end as the fire is coming out the pinion seal and the bottom. THE BOTTOM OF THE PUMPKIN WAS GLOWING AMBER. OH HOLY CRAP. I run out of Coke and the fire still burning. So I ring 911 and they send a fire truck but it was out by the time they get there. We load the truck up for the 20 mile tow and while it's on the flat bed I take a gander and see the bottom of the rear end is broken and has a nice hole it it. Look on the ground where the truck was sitting and there's barely any oil there and what is there is jet black. So, with that all said, I need a new rear end near St Louis. Sorry for the long rant.
'01 Camaro Son, you just can't get there from here... |
Re: Pumpkin on fire!
WOW sorry to hear about the troubles.. look on the bright side... time for a 5 lug swap?
94 ls swap silverado 65 Pontiac 78 c30 crew cab dually (parted and gone) 82 c30 crew cab dually ( now building ) 91 r30 crew cab dually (parted and gone) 69 swb-sold 71 lab sold all in progress......__ ..........._______ |__\__ ..........|__(O)______(O)] ........................ |
#3 | |
Embrace the Redneck
My wife would kill me... ![]()
well while the beds off for the tank u can put drop springs in and clean and paint the frame and while ur painting the frame and doing disk u can lift the cab and paint and put new bushings in and well while everythings off u can send it to the paint shop for some new color..... just sayin
very sorry to hear that man sucks when they take a dump on us but its usually only a one time fix with this kinda stuff good luck
Big Red - Now its a SWB!
That really sucks, but at least your just gonna have to find a rear. It would have been much worse if it had all went up in flames or if it would have lost an axle and you went out of control or something like that. Let us know how the search goes!
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
shouldn't b bad finding a new rear//fire extinguishers are an even easier thing to find
a rear mounted gastank would of spiced things up
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 03-06-2011 at 10:16 AM. |
Redefining LowBudget
Glad you adventure was just that and evryone is home safe....
think about that 5 lug convertion and if the wife has anything to say tell her the truth...its cheaper than a new truck payment??? |
Yep, cheaper than a new truck payment. And you can stop when you don't have the money and no one will come tow it away in the middle of the night. Glad to hear it wasn't more serious. Good luck with the frame off resto.
Glad to hear it turned out OK, could have always been worse. Two years ago close to where you were, I blew a PS pressure line during morning rush hour traffic in the 71. A huge dark cloud of fluid from hitting my hot L/H pipe had folks thinking I was driving a truck on fire. But luckly the fluid didn't ignite just created a cloud across the west bound traffic causing everyone to slow to 25 MPH. Maybe there is some bad vibes from the ol former Chevy truck plant floating around the area?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
i can remember a time in 1983 i just got back from a 200 mile trip. Pull in to town and lost a axle.I was lucky going 25, when that happen.Hate to think what would happen to me and the truck if that would happen on the interstate.
In 2005, I was going 90 MPH on an interchange ramp with a long curve in my 67 Lemans when it dropped the driveshaft from the front end. Pole-vaulted the car about a foot up in the rear, spun sideways, driver's side first, and luckily kept it rubber side down. Blew the trans tunnel a lot wider, blew open the rear diff wide open, gears all over the highway, cracked the trans bellhousing, wrapped up the exhaust pipes, bent 1 wheel, blew out a tire, dented a front fender from a plastic road marker thing, and the cop measured the shid marks at around 900 feet!
I've also lost an axle before, same vehicle, on the highway at speed! Sucks! I feel your pain, but I have a free 12 bolt you can have, if you want to come to Mass. to get it!
T.Y.N Custom Works..... Because "Stock" Sucks! 1971 K 10 GMC Long Bed 1977 Formula T/A Frame off Resto-Mod ![]() 1995 FXDL Harley Low Rider 1985 C10 ShortWide 91 Burb front. |
#13 |
![]() Join Date: Jul 2001
Sorry to hear about your troubles. Glad everyone is ok and it could have been alot worse. Hope you can get a rear soon.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
#14 |
Factory Strippers Rule!
![]() Join Date: Mar 2009
Biggest tragedy of the whole story was that you had to waste your Coke... good thing it wasn't a Mountain Dew or there'd be a good chance you'd find Longhorn Man licking your pumpkin in the middle of the night.
![]() Glad it didn't go as bad as it could have.
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
#15 |
youi know really we all want pics of it??
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#16 | |
Roadtrip!
![]() Join Date: Feb 2003
Should be easy to find another 6 lug rear just to get up and going again.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#17 |
Sucks you had trouble with your rear axel, it could have been alot worse for sure. Its always easy for the snowball effect to kick in, but if it were me I would take the oppurtunity to add positrack to my rear end and possibly upgrade the gear ratio if you wanted. Drop springs or blocks are an easy swap and can be done later, so is a rear mounted tank. But a rear end rebuild is a little more involved. I would take care of that area before I did anything else in the back.
#18 |
Who's got steelies?
![]() Join Date: Feb 2006
Ouch! Glad to hear you came out OK though.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
#19 | |
![]() Hey better the rear end than the motor right... And now you have a excuse to spend money on your truck.
1969 Chevy c20(Miss Hackjob) Last edited by treveiger; 03-06-2011 at 02:22 PM. |
#20 | |
#21 |
laying low
![]() Join Date: Mar 2001
Steven, you gotta check that rear end lube every now and then dude..
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#22 |
its all about the +6 inches
took care of that annoying whine at least.
![]() Kinda reminds me, my eaton has been whining for some lube the last couple years |
#23 |
Post some pics up of your rear end.
#24 |
laying low
#25 |
^^^What happens in the thread stays in the thread
1969 Chevy c20(Miss Hackjob) |
