Old 03-06-2011, 02:56 AM   #1
60ratrod
yes, i do
60ratrod's Avatar
thinking of getting halo headlights for my 01 tahoe
so has anyone had issues with their halos? the last set i installed was on my 94 and i liked them, but slowly the halos burned out, starting with the led "dot" within the first 6 months that i had them. i ended up pulling them apart and replaced all of the leds with amber leds and went with a slightly larger resistor which solved my issues, but couldn't get the "dots" to work, which wasn't an issue in my opinion. so has anyone had an issue like this? i'm just trying to get an idea of whether i should pull them apart when i get them or if they lasted for a while. thanks!
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 03-06-2011, 07:02 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: thinking of getting halo headlights for my 01 tahoe
All I know is don't buy cheap ones.......learned that the hard way. I wasn't able to see anything at night and they turned yellow in three months. If you buy a well know brand to began with you should be ok.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 03-06-2011, 07:17 PM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Subscribed!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 04-28-2011, 02:20 PM   #4
Capcity82
Capcity82's Avatar
I'm installing some on my 99 burban. the instructions that came with it were kind of vague. Does anyone know hot to wire them. Instruction said red wires to positive wire of side marker, black wire to negative of side marker. There is also a green wire but it doesn't say where it goes. any help on this?
Capcity82 is offline   Reply With Quote
Old 04-28-2011, 07:20 PM   #5
60ratrod
yes, i do
60ratrod's Avatar
You can wire those up in one of two ways. First off you can tie them in to your running lights and have them come on when you turn on the running lights, or you can run a toggle switch into the cab and have just the halos come on. The red is going to go to a 12vdc switched hot source, like the toggle switch or the running lights. The black is going to go to a ground. On my 94 gmc that i put some halos on i drilled and grounded the halos to the core support. The green wire i'm not certain where that goes since the halos i had didn't have a green wire. Hope this helps
Old 04-29-2011, 03:08 AM   #6
60ratrod
yes, i do
60ratrod's Avatar
now that i think about it, do those halos come with either a dot or set of dots or an extra light somewhere in the housings Capacity? if so then that is more than likely what the green wire goes to.
Old 05-27-2011, 12:42 PM   #7
Capcity82
Capcity82's Avatar
I tied the red one to headlights and they work I grounded the black wire. the halos are a separate bulb. So does that mean that i wire the green to the red one as well?
Old 05-27-2011, 07:49 PM   #8
60ratrod
yes, i do
60ratrod's Avatar
you need to figure out what wire operates what led. most people tie them into their running lights
