03-06-2011, 05:39 PM | #1 |
366 dumptruck motor in my 62 Panel
Got a strong 355 in her now with a mild cam...Would putting the 366 in it be worth the trouble of the swap to a big block. Also doing 86 Sub susp. swap to get all the upgrades in one shot. Found some info on hoppin up a 366 online.
03-06-2011, 06:27 PM | #2 |
Re: 366 dumptruck motor in my 62 Panel
I say no, unless you are into spending more money to make less power. It's only 11 cubic inches bigger than your small block. Just my opinion.
Slowly but surely getting it done. |
03-06-2011, 09:17 PM | #3 |
A decent 355 will out perform a 366 any day of the week and get a lot more mileage at that. I wouldn't mess with it if I were you.
03-07-2011, 01:27 AM | #4 |
60-66 Nut
Absolutely not worth the effort to swap in a 366. Those are tall deck truck engines built for low rpm power, and the 366's even lacked that. If you want a big block go with a 454, 427 or even a 396 from a passenger car or light truck.
03-07-2011, 02:25 AM | #5 |
absolutley NOT!!!!!!!
03-09-2011, 10:02 PM | #6 |
Thanks for input! Always had smallblocks and was thinkin a bigblock would be fun.
. Posted via Mobile Device |
03-09-2011, 11:20 PM | #7 |
A big block would be fun, just not a low performance boat anchor version.
03-09-2011, 11:47 PM | #8 |
A friend of mine had a 366 and wanted to hot rod it so we came up with a combination where we used 292 chevy rods and 383 pistons bored it to 4.00 and adjusted the stroke so the piston was .010 above deck and it ran like a champ ..........
03-10-2011, 12:31 AM | #9 |
The only problem with that Awbrown would be he can pick up a late model big block running with what he would be paying out in machine work, price of big blocks are cheap...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
03-10-2011, 01:02 AM | #10 |
How do you "adjust" the stroke?
03-10-2011, 04:32 PM | #11 |
We do a lot of stroker combinations for folks on everything from 2.6 chryslers to stovebolts to nailhead buicks , you name it we have stroked it .. On any combination you have to do some math .. deck height minus 1/2 of the stroke ,the rod length and compresion height of the piston ..
Example , the 366 is a 10.200 deck , the stroke is 3.766 , the rod length of a 292 rod is 6.758 (average they do vary ) and a common 350 chevy piston is 1.540-1.560 depending on manufacturer.. half of the stroke on a 366 would be 1.883 plus rod length ,6.758 plus compression hgt of the piston 1.550 average equals 10.191 , meaning it will be .009 down from deck .. if the components don't stack up more than .010 or so out of the deck it will work , you just need to confim you have piston to valve clearance and your good to go... cost to do it , pistons and rings 110.00.. 292 rods ,your on your own here , and grind the crank on stroke 120 , to offset grind runs 200 (you actually widen the bbc to 2.075 because the 292 rods are wider)..plus balance and bore job (all regular rebuild expenses...) you can destroke a 454 crank to 3.940 and use 292 rods and a KB744 piston and it gives you a 396 that has a very light bobweight...... So a 366 may be useless in its stock form , but they are far from useless when you use your imagineation.. Thats what hotrodding is all about .. Last edited by awbrown; 03-10-2011 at 05:09 PM. |
