Building Dreams out of Dimes!
Be Cool Aluminum Power Cooling Modules (radiator with electric fans) is it worth it?
I have a sb400 and I live in texas where it can get well over the 100 degrees no problem. My engine should be around 450 hp or better at a best guess.
Just wondering if this aluminum radiator and dual electric fan setup was worth it. My truck is not a show truck by any means but I want to keep my engine cool as possible. Well... What do you say for $1,694.95 ? http://www.summitracing.com/parts/BCI-86013/ ![]() Brand Be Cool Manufacturer's Part Number 86013 Part Type Radiators Product Line Be Cool Aluminum Power Cooling Modules Summit Racing Part Number BCI-86013 Radiator Style Crossflow Overall Width (in) 35.000 in. Overall Height (in) 21.000 in. Row Quantity Dual-row Radiator Finish Natural Radiator Material Aluminum Transmission Cooler Yes Inlet Location Upper driver side Inlet Size 1 3/8 in. Outlet Location Lower passenger side Outlet Size 1 5/8 in. Core Height (in) 18.500 in. Core Thickness (in) 2.000 in. Core Width (in) 27.500 in. Tube Size 1 in. Fan Included Yes Fan Diameter (in) 11.000 in. Fan Quantity Dual Maximum Fan CFM 2,780 cfm Blade Color Black Blade Material Plastic Shroud Color Black Shroud Material Plastic Quantity Sold as a kit. Notes With engine oil cooler. Be Cool aluminum radiator power cooling modules are designed to properly cool your vehicle. Kits include: * Aluminum dual 1 in. core performance radiator with oval fluted tubes * Aluminum fan mounting brackets or straps with hardware (where applicable) * Diamond-cut, vented coolant recovery tank * Fan wiring harness(es) with 40 amp relay(s) * Be Cool billet radiator cap * One 16 in., dual 11 in., or two 13 in. high-torque Euro black electric puller fan(s) (in selected kits) * Natural or polished aluminum finish * Bolt-in installation * Fan upgrades sold separately Warranty |
| Bookmarks |
