Old 03-06-2011, 10:24 PM   #1
AusTx68
AusTx68's Avatar
Filling Holes in Firewall - My Solution
As they say, hindsight is 20/20. When I had my cab painted I overlooked having the holes in the firewall sealed up. Had I been thinking, every hole would have been welded and painted. Instead I was stuck with all those open holes in the firewall. today I finally decided to do something about it.
I picked up some trim fasteners from my local autoparts store. These are the same fasteners used to hold door panels. Out of the package they are black, smooth and glossy looking. I used light sand paper to remove the gloss then sprayed them with primer. Once dry, I lightly sanded the primer with 600 grit. I then spray them with a base coat of Atomic Orange from a rattle can. After an hour I went over it with automotive clear also from a rattle can. The results were better than expected. In the photos below they are sitting over the holes but not yet secure. I plan to cut small pieces of leftoever Dynamat to cover the holes from the inside. Then pierce a hole and push them into place.
I still need to fill the remaining holes and add grommets where the wires pass thru. When it's done it will look way better than all those holes!
After spraying base coat Atomic Orange
After applying clear coat
Firewall holes before
Firewall holes after
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 03-06-2011, 10:30 PM   #2
DT1
DT1's Avatar
Re: Filling Holes in Firewall - My Solution
So simple. Looks great.
DT1 is offline   Reply With Quote
Old 03-06-2011, 10:51 PM   #3
firedog
firedog's Avatar
thats perfect, just the solution i was looking for! just gotta love the info on this board
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 03-06-2011, 11:09 PM   #4
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looks great. Much better than all the unused holes there! Great job!
--Josh
Old 03-07-2011, 12:25 PM   #5
dfwright
dfwright's Avatar
Excellent Idea!
Marking for future reference
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
