rim backspacing and to narrow or not to narrow
I am building a 1969 c10 reg cab short box 2wd. I am almost done my frame just installed a scotts hot rod supper slam front end kit and a cpp rear air ride kit. I step notched the frame just behind the cab and boxed it.
now that you know what i have done so far what i am aiming for here is a good street truck i can drive in the summer that will handle decently well and have lots of power to put a smile on my face with. for power it will be getting a gm ls 376/515 crate engine backed up by a t56 6 speed. I have two questions the first being what backspacing are you guy running on your rims i want 20s all the way around with probably 9x20 in the front and 13x20 in the rear. This truck will lay frame and i will tub out the rear as well as raise the bed floor up for the stepped up frame. my second question is what rear ends are you guys running i have a guy that can build me one locally and i know i will have to narrow it. I just want to see what you guys are running with your bagged truck and what widths you running. I have built lots of vehicles but up to this point its been allot of 4x4s this is my first low ridder build i have done any info , tips and pictures you have for me would be great thanks in advance for the help. |
VA72C10
![]() Join Date: Mar 2008
Re: rim backspacing and to narrow or not to narrow
Moved to suspension forum so you'll get better, more educated responses.
To go with a 13" wide rear tire as you said you will need to narrow the rear. On backspacing, every truck will be different and will depend on how you lower it (spindles/dropmember/etc) If you have more info on your plans for the front and rear that will help
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
13" wide rear wheels does not 'require' narrowing the rear housing. It requires the proper back-spacing.
If you want a 13" wheel w/a deep lip & less back-spacing, then you need to plan on narrowing the housing (or buying a suitable swap housing). If you look around (search the net), an aftermarket 9"/12-bolt g-body rear housing would be a good choice as it's 4" narrower (2" per side) vs. a 6x-69 12-bolt housing. You might be able to find one @ a good price & just whack the existing brackets off & weld on some truck arm brackets. This is what I was searching for (for my RetroRod project) until I came across a built 12-bolt that was the right length, new gears, posi & axles for the price of an aftermarket 9" housing/axle pkg.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-07-2011 at 12:12 PM. |
VA72C10
Is it even legal to run 13" rear wheels without a DEEEEEP lip????
Absolutely not!! Everybody needs deeeep lip wheels....
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler 1968 Chevy c10 shorty Stepper (Patina LS project) 1967 gmc custom Long Box (Farm Truck Project) |
#6 | ||
Happy to be here
![]() Join Date: Mar 2000
So I am not the only one that the super deep dish bothers? I LOVE wide wheels, but feel that the dish front to back should be comparable.
Agreed
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
Redefining LowBudget
Ummm I have 13" wide wheels..I just had my stock rallies cut and widened??? it was cheap and I didn't have to swap axles or shorten them either??? tub yes!!! and I run 15 or 18" wide M/T's all the time
theres pics in my build
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#10 | |
Sure.... it's possible to do just like lots of guys weld their differential spider gears for a 'poor-mans' spool. That doesn't mean it's correct. I'd like to learn what your process is.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-07-2011 at 07:23 PM. |
motor exploder
I'm running 18x12 on a stock width '69 rear. my bs on the rears is 7.5". I followed SCOTI & N2trux philosophy on this, plus I didn't want or have the money to spend on custom, super deep lip wheels AND narrow the rear. As you can see in the pic below, there is plenty of room from the inside wheel to the framerail. I have a stepside bed, and I'll graft in some fleetside tubs to clear the wheels, but nothing has or will be done to the frame or rearend housing. For me, I feel like I have a good match from front to rear as far as the 'look' goes, and then surprise, surprise when you see it from the back with a 335/30 tire tucked up under there.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
![]() Join Date: Feb 2011
hey bosshogg......what brand tires and wheels.,...any pics of the wheels? love the tread!! how tall are the rears compared to the front???
#13 |
motor exploder
wheels are the Boss 338, kinda like belly buttons around here these days... I have more pics of them on my profile page.
Tires are BFG gforce kdw's, 245/40/18 front, 25.7" tall, 335/30/18 rear, 25.9" tall. I would have liked to run the 275/35's in front, but of course, they came out after I got the 245's... Too bad no one makes a 335/35 anymore because a 275/40 front and 335/35 rear would be BEAST ![]()
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 03-07-2011 at 09:33 PM. |
#14 |
do you think the tires are going to fill the wells ok?? they are alot shorter than the stock 29" tires..I fought over that when I was building my truck I wanted wheel/tire combo that would keep things close to stock
on a side note how do you like that Scotts front end....and I look forward to seeing your combo with the body on
#15 | |||
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-07-2011 at 11:57 PM. |
#16 |
Ugh..... you guys are bad for me. Now I want to tub my truck and go the Bo$$Hogg route.
#17 |
motor exploder
Is this what you had in mind topher??
don't do what I did, just skip my little bs and go for the throat.... 22x14's with the 405 width Pirelli's.
#18 |
That's a very, deep, dish.........
#19 |
Thats the exact look i am aiming for bosshogg i might even go with 22s after seeing that pic
#20 |
motor exploder
Come to think of it, those rear wheels might be 24's - I don't have the hard copy of it, thanks to a coworker that 'borrowed' that issue from me. You can find it online at www.truckinweb.com, under the 'featured trucks' tab.
#21 |
hey bosshogg what is the backspacing and width for the front rims in the first pic you posted ?
#22 |
motor exploder
22x8.5, but I don't know the bs on them - but from the looks its a lot, since the wheel face it almost flush with the wheel lip. The rears are 24x14's I did check on that too.
#23 |
sorry i was talking about the first pic you posed of just the frame with the 18x12 on the rear with 7.5 backspacing do you know whats on the front of that c10 ?
#24 |
motor exploder
Yeah, I hope I know, since that's my truck (frame)
![]() The fronts are 18x8 with 4.5" backspace.
#25 |
