Old 03-07-2011, 10:37 AM   #1
Raidersfan78
lowering springs
Does anybody know if I would have to do anything special if i go with 3 inch and 5 inch lowering springs on my 66 c-10. Please keep in mind this is a build on a budget (aren't they all) just a driver. If anybody has any pics of any trucks with lowering please send them. thanks
Raidersfan78 is offline   Reply With Quote
Old 03-07-2011, 11:07 AM   #2
Blue Heeler
Blue Heeler's Avatar
Re: lowering springs
Do a 3"front and 4"rear you won't have to do anything 5" in rear you will have to notch!
Blue Heeler is offline   Reply With Quote
Old 03-07-2011, 11:10 AM   #3
tenni126
If you're looking for around 3" I'd consider saving a bit for dropped spindles. Saves the geometry and keeps lower arms a little higher.
tenni126 is offline   Reply With Quote
Old 03-07-2011, 11:11 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
You will need to add shorter shocks.
Keith
Convert to disc brakes.
Old 03-07-2011, 01:57 PM   #5
lakeroadster
In addition to shorter shocks you will also need to relocate the rear shock upper mounting position. Check out this thread: Upper Shock Relocation 1963 through 1972
For pictures check out this link: Static Drop Photo and Data Thread
And, FYI, if you look at the Static Drop thread you will notice a lot of guys are running 5" rear drop springs and did not c-notch their frame. That's likely because they removed the stock rear bumpstops. That's what I did.
Good luck!
lakeroadster is offline   Reply With Quote
Old 03-07-2011, 01:58 PM   #6
SIR
SIR
SIR's Avatar
This is a 3/4 drop spindels/springs. when it setteled down to it's "normal" ride hight it was closer to a 4/4 hope this helps....
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 03-08-2011, 04:51 PM   #7
Raidersfan78
nice! that is the look i am looking for!!! except i am going with springs. thank you
Old 03-08-2011, 05:16 PM   #8
kieth
kieth's Avatar
The spindles are really the least expensive way to go, do you have coils or leaf springs on the rear ?
kieth is offline   Reply With Quote
Old 03-08-2011, 05:29 PM   #9
lakeroadster
Originally Posted by kieth View Post
The spindles are really the least expensive way to go.....
Kieth,
How do you figure spindles are the least expensive? Remember the original post said "budget" and didn't go into swapping disc brakes and the like.
Front drop coils are about $120 for a set.
Spindles are about $300.
Is this some of that "Fuzzy Math" that I hear politicians speaking about?
Old 03-08-2011, 09:43 PM   #10
Dble Hump
Dble Hump's Avatar
You should go with jeep springs in the rear. You can pick up used ones for less than $30. This will lower you truck about 3 to 4 inches.
Here is a link to a post about jeep springs:
http://www.google.com/url?q=http://6...Xu05bgtJsvC4EA
You can also make your own drop blocks, but you will need to have someone make you new ubolts.
The rear is cheap to lower, but the front is what cost the bucks.
1964 Chevy C10 LWB
Dble Hump is offline   Reply With Quote
Old 03-08-2011, 10:31 PM   #11
72freak
Rottenwood Garage Member
72freak's Avatar
This is a 3-5 with springs ONLY!
No C-notch, no drop shocks, nothing....Its all good and rides fine
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 03-09-2011, 09:33 AM   #12
lakeroadster
Very nice! Where did you get 3" front drop springs? Did you use 2" and cut a coil off?
Old 03-09-2011, 09:56 AM   #13
72freak
72freak's Avatar
I cant remember...it was abour 4 years ago....I will look...CCP maybe?
Old 03-09-2011, 02:45 PM   #14
Scot_Douglas
Scot_Douglas's Avatar
CPP 2.5" drop spindles are $219 and you can get 10% if you talk to cppjeff.
Just did this for my 66.
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 03-09-2011, 03:28 PM   #15
glos55
glos55's Avatar
I've been cutting coils way before there were dropped spindles, lowering springs,bags and etc. If raidersfan78 is on a budget and all he wants is a little attitude for his daily driver then springs will do just fine. I do admit there is a limit with springs.. and four inches is it. Dropped spindles are the best way...... thats why they were invented! Over the years I've lowered 55/56/57/65 and 66 chevy's by removing a coil or two and drove these cars for years without a problem. If you're going Delmo then we all know whats involved! In this case springs will do!!!
glos55 is offline   Reply With Quote
Old 03-09-2011, 04:30 PM   #16
Scot_Douglas
My 66 lowered itself by breaking about a coil on each side of the front end.
1966 C10
Build 'Fread
