76 power steering box
Morning folks.. I was on craiglist earlier and saw someone selling a 76 chevy powersteering box and pump for 25 buckaroos.. .. is this steering box a direct fit to my 72 gmc manual steering. I know the manual is shorter with some sort of adapter. and if heard of notching the bumper bracket... just woandering if it fits as my steering is pretty loose anyways. Thanks yall and happy monday!!!
Hellasick
![]() Join Date: Jul 2006
Re: 76 power steering box
surprised I'm the first on this. Yup, it will fit just fine, but the Pitman arm is different for the power unit. IIRC the pitman arm is what makes up the difference in the length of the box. You will prob. need to clearance the bumper bracket. Nothing a sawzall or angle grinder cant fix. And at $25, if it doesn't work, prob. less that the core charge at the parts store.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
Yes it will bolt right up. I put a 76 box out of a junkyard on my 70. I did have to notch the bumper bracket. The intermediate shaft ( shaft that connects box to column )on yours should work, if it's too long they are collapsible and you can shorten it up if needed. You're probably gonna have some issues with the pump. Those pump brackets are designed to be used with a long water pump. Our trucks use a short water pump. I ended up finding a pump w/ brackets off a 71 or 2. Your gonna need a 3 groove crank pulley too if you don't already have one. Hope this helps.
![]() ![]() ![]() 1970 Chevy C10 LWB 307 3OTT 3.73 gear |
#4 | |
Hellasick
tHANK YOU GENTLE MEN.. BIG HELP!!!
