03-07-2011, 01:02 PM | #1 |
drop spindle versus stock spindle
how can you tell the difference? i got a front crossmember and controls arms and spindles from a buddy but dont know the difference from a dropped one or stock one.. truck has no springs and was roller frame so cant tell
03-07-2011, 01:32 PM | #2 |
Re: drop spindle versus stock spindle
The steering arm where the tie-rod end seats is virtually straight across from the spindle stub on a stock spindle & drops down on a dropped spindle.
03-07-2011, 02:15 PM | #3 |
Check out the pic in the #12 post http://67-72chevytrucks.com/vboard/s...d.php?t=448078
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
