![]() Join Date: Nov 2010
core support question
I have a 67 core support that's rusted I also have a 70 core support that's in good shape. Question is can I use the 70 one on my 67 the only diff I saw was the headland bracket thanks guys
Posted via Mobile Device |
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: core support question
ttt
Restoration Virgin!
the radiator support bushings are different...think you'll need to use the 67 ones.....as well as the grill support and latch from the 67....not sure about fitment though...
anybody?? EDIT....saw this thread going too asking the same question...http://67-72chevytrucks.com/vboard/s...d.php?t=447575
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 03-08-2011 at 10:26 AM. |
![]() Join Date: Sep 2005
from what i have been told they are very different
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
67 core support
70 core support sorry for the ugly pics
i measured them same size all the way around. the battery tray bolts and radiator hold down bolts fender bolts in the same location. only diff i saw was the btacket on the headlamp mounts. just was asking to see if anyone had tried this
member #16
![]() Join Date: Dec 1999
I dont see why not. I put the 69-72 headlight brackets on a 1968 support and it worked good. Just get you headlight mounting holes in the correct spot. I think the different mounts are the frame brackets, which have smaller holes not the supports.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Yes, I just drilled out the spotwelds on the headlight supports in order to remove them. Underneath the 69-72 headlight supports are 67-68 headlight provisions.
Dano
![]() ![]() It ain't yours, if you didn't build it! Last edited by Dano69c10; 03-08-2011 at 04:56 PM. |
