Old 03-07-2011, 02:47 PM   #1
scott72
scott72's Avatar
Question 68 3/4 ton posi rear differential maxi tract R axle
Anyone think I would have any issues swapping this out with my current 12 bolt on my 72 3/4 ton c10?
http://67-72chevytrucks.com/vboard/s...d.php?t=450950
Looks like a good deal, but want to make sure I can use it before I commit to buy it.
Thanks for the help.
scott72 is offline   Reply With Quote
Old 03-07-2011, 06:35 PM   #2
Blazer1970
Blazer1970's Avatar
Re: 68 3/4 ton posi rear differential maxi tract R axle
C10 is a half ton
12 bolt is a half ton axle
That axle is a Dana 60, and it should bolt into your half ton truck but it is 8 lug, not 6 lug like your 12 bolt.
Blazer1970 is offline   Reply With Quote
Old 03-07-2011, 07:28 PM   #3
scott72
scott72's Avatar
Thanks for the help. I was thinking 3/4 ton springs.
Old 03-08-2011, 08:38 AM   #4
What do you actually have? If you have a coil spring truck then that rear will work,but you will have an 8-lug rear. Are you saying you have a '72 C/10 with 3/4t springs? In that case you have 5-lug wheels,right? If you have a C/20,which is a 3/4t truck,this axle is just for you.
Old 03-08-2011, 11:43 AM   #5
scott72
scott72's Avatar
It is a C10 with coil springs, and I was told from the previous owner he put in 3/4 springs in. He was hauling trailers around with it.
Yeah, the wheels are 5x5.
Any disadvantages of running a 3/4 axle on a 1/2 ton truck besides having to get new wheels, and probably new brakes?
Posi would be nice, but want to make sure I am going in the right direction.
Old 03-08-2011, 12:02 PM   #6
cdowns
cdowns's Avatar
i've seen posted that some of those bigger rears that replacement brake drums aren't available. i'd check into that b4 buying
Old 03-08-2011, 01:04 PM   #7
Beat68CST
Beat68CST's Avatar
Finding a drum for me wasn't too bad, found one that was damn near identical, only .020 of an inch shallower.
It did cost $160 though...
Beat68CST is offline   Reply With Quote
