Old 03-07-2011, 07:10 PM   #1
mkschwall
3 spd transmission suggestions?
I have two teeth missing in the counter gear in my Muncie 318 (4 bolt side cover) 3 spd transmission. This is the truck that my father drove to work every day, and I want to keep it stock (I learned how to drive on it in 1971). Chevy c-10 fleetside, engine 230 CI, 3 speed manual transmission, no overdrive. Any suggestions?
mkschwall is offline   Reply With Quote
Old 03-07-2011, 08:01 PM   #2
biohazardbill
Re: 3 spd transmission suggestions?
How about a "Muncie 318 (4 bolt side cover) 3 spd transmission"
biohazardbill is offline   Reply With Quote
Old 03-07-2011, 08:08 PM   #3
k1rodeoboater
I was gonna say that or a BW T-85 3spd with overdrive
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 03-07-2011, 10:37 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
speedway sells a rebuilt 3 speed for around $400
John
1999 Toyota Tacoma 4x4
Old 03-08-2011, 01:59 AM   #5
andyh1956
when i was in high school the welding teacher's old crash box in his '65 bit the dust. he bought a later sycro 3 spd from one of the machine shop students that got it from a wrecked nova. we were gonna swap it for him after school. when we saw it it wound up being a bw st10. he was gonna give it back cause he didn't want to hack up the floor for a new shifter (which didn't come with the trans) any way, one of the retired army guys that was going to school at night studied on it & came up with a solution. we installed the trans & he modified the linkage to fit the shift levers on the side & installed an electric solenoid on the reverse lever. you had to leave the shifter in n and then flip a switch for reverse to engage but it worked. that old 283 sure liked that column shift 4 spd!
andy
andyh1956 is offline   Reply With Quote
Old 03-08-2011, 02:28 AM   #6
Blue72slab
These transmissions are pretty easy to work on. If you have the service manual it pretty much walks you through it. I would pull it apart and get the stuff you need to make it as good as new and you will save some money in the process.
Larry
1972 Chevy C20 Custom Camper
1968 Chevy Camaro RS
1980 GMC K5 Sierra Classic
Blue72slab is offline   Reply With Quote
