proportion valve
Any suggestions where I could purchase a disc brake proportion valve for my '71 c20? I tried the local NAPA, Kragens, etc. I know LMC has them, but they're like $140.00..
I recently replaced my master cylinder, but fluid is still transferring from the rear reservoir to the front. So I suspect the proportion valve is leaking. Thanks!
___________ Greubin '71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI ![]() |
Re: proportion valve
I had the same problem after buying a new master cylinder from advance auto. Like you, I suspected the prop valve and bought a known good one and it made no difference, Its a fairly simple device that doesn't often fail. Bought a remanufactured master cyl from Napa and that solved my problem. Some of the new parts that are made overseas are junk, I would try another Master Cylinder, preferably a reman.
Good luck Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
cpp has a nice master cylinder / proportioning valve for pretty cheap and it looks nice.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!! |
www.getdiscbrakes.com
Thats where I got mine at. Master cyl,bosster and valve. |
junk yard
73-87 truck |
