03-07-2011, 11:36 PM | #1 |
Rear main seal
So I am going to attempt to replace the rear main seal, one mech. told me im gonne have to drop the tranny, and another said i can access it by dropping the oil pan. Any advice on this? any special reading i can do that will help?
The motor is the original 253 inline 6. I'm new to the forums and any help would very much appreciated. Mike |
03-08-2011, 01:32 AM | #2 |
Re: Rear main seal
greetings. do you mean a 235? if so, it should have a rope seal around the crank under the rear crank bearing. it can be got after by removing the oil pan & the rear main bearing cap. it will probably be rock hard & will come out in chunks. be careful not to scratch the shaft. they make a tool for the job & i have bought several over the years but they never worked for me. when you get the new one in try to stagger the ends a little off with the parting surface of the block & cap so the oil won't have a straight shot out of the engine. hope this helps a little.
andy |
03-08-2011, 07:08 PM | #3 |
Re: Rear main seal
Mine is leaking too, sounds like a pain!
03-08-2011, 07:31 PM | #4 |
"Where were you in '62?"
Re: Rear main seal
Langdon’s Stovebolt Engine Co.
http://stoveboltengineco.com/
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
