Old 03-08-2011, 02:24 AM   #1
sixshooter798
Desert Rat
sixshooter798's Avatar
Where is the...
My buddy has an 86K5 Blazer with a 350. His coolant temp gauge is stuck at zero. I swapped his out for one of my spares and that didn't help, and I assume this means a break in the power line. My question is; where is the temp sensor on a truck like this? Pics would be mighty helpful, if anyone has them.
sixshooter798 is offline   Reply With Quote
Old 03-08-2011, 06:23 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Where is the...
drivers side screwed in the head
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-08-2011, 06:30 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Where is the...
look in between the first two cyclinders,brassy piece,with the wire on it
John
Old 03-08-2011, 09:24 AM   #4
James McClure
One shot, one kill.
Re: Where is the...
Sixshooter. After you locate the sender take the wire off it, turn the ign to "on" and observe guage, should stay at "0". Ground the wire and guage should go to overheat. If it follows what I said the sender is bad. If it still fails to operate, check guage fuse. (if gas guage works, fuse is ok) If fuse is ok problem is more than likely the connection between the dash plug OR a bad connection at the 3 little steel clips that connect the guage to the printed circut. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
