Old 03-08-2011, 08:56 AM   #1
biohazardbill
A Question for those laying frame with a stepside
What tire/wheel size combo are you using for the rear? Offset? Do you have room to go bigger if you wanted? Stock axle?
If we decide to go this route we will be using the stock axle and are trying to figure out wheel/tire combo for the rear.
biohazardbill is offline   Reply With Quote
Old 03-08-2011, 09:17 AM   #2
lakeroadster
Re: A Question for those laying frame with a stepside
Are you wanting something real wide or just big diameter or both?
If you go with custom offset wheels you can go 10" wide wheels no problem. With a stepside you don't have much room for a lot of dish (front offset) unless you narrow the rear end or widen the bed (see my build thread). There is a lot of room however for additional back spacing.
Here are some links for ya. Maybe PM the owners for specifics?:
http://67-72chevytrucks.com/vboard/s...ghlight=wheels
http://67-72chevytrucks.com/vboard/s...t=thread+wheel
http://67-72chevytrucks.com/vboard/s...light=stepside
lakeroadster is offline   Reply With Quote
Old 03-08-2011, 09:23 AM   #3
biohazardbill
Both-- I would like to fill up the flare as much as possible without cutting into the bedside if at all possible. Not sure if I will have to cut into it for the notch or not...
I did PM one user but he has yet to respond, I will be getting parts in any day now and need to pick a truck to start on lol.
