Old 03-08-2011, 09:30 AM   #1
engineco713
engineco713's Avatar
What did I do to my tranny????
Hey all,
I have an 86 C-20 with about 130,000 miles with a 350 engine and 4 speed with granny setup. I'm not using it as a daily driver but my "new" truck was in the shop so I drove it to work. Upon stopping at 7-11 I went to start the truck and it seemed like the clutch was engaging even though I had it to the floor. I had to shut off the truck to get it to shift into neutral. I was able to get it started and shift but when I pulled up to the first red light the engine was dying out like I had the clutch out. I can't get it into "L" at all, and 1st is a bear, 2nd and 3rd shift fine. So then last night as I'm nursing it home and I go to back into my driveway and I can't get it into reverse while its running. So I had to shut it off and back up as I was starting it to be able to move it. To me it seems like the clutch isn't releasing but someone said it could be a throw-out bearing. I just had the clutch master cylinder replaced about 10 months ago and have only driven it about 1000-1500 miles if that since the replacement. I also read it could be air in the master cylinder but I haven't had any problem before now. Can anyone provide any insight?????
1993 Chevy Suburban 4X4 (Off duty driver)
2012 Chevy Impala SSV (Work Vehicle)
2008 Harley Road King (Play toy)
engineco713 is offline   Reply With Quote
Old 03-08-2011, 10:18 AM   #2
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Re: What did I do to my tranny????
Bad slave cylinder would be my guess. My buddy's 91 Camaro did the same thing, and would constantly drain all the fluid out of the clutch master cylinder because a seal in his slave went bad after only 8 months. Every time it started going low, it got harder and harder to get the trans out of gear, and when it was extremely low it wouldn't dis-engage from gear at all. There's also a very specific way to bleed the slave cylinders out; they're nothing like bleeding brakes.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 03-08-2011, 10:23 AM   #3
engineco713
So how hard is it to replace? The fluid level was fine in the master cylinder. Also anyone know what type tranny that is so I can look for a replacement?
Old 03-08-2011, 10:41 AM   #4
lindstromjd
I can't say for the 465. My experience comes from the T5. It sucks with only one person though; having a second pair of hands really made a difference.
As far as bleeding the slave... You open the bleed screw, and let it gravity bleed until it comes out as a steady stream. Next, close the bleed screw, and push the slave's actuator arm all the way in. Then, charge it up by pushing the clutch pedal a few times until you get good pressure. If it still feels like there's air in the system, repeat the process.
Doing that from memory; I might have forgotten a step. But those are the important steps.
-357 / 700r4
-350 / TH350
Old 03-08-2011, 10:48 AM   #5
engineco713
Ok....thanks....I'll see if that works.
