4/6 drop???
I know this has probably been covered a hundred times on here, but I honestly couldn't find the answer while looking through previous posts. I just got off the phone with cpp to order a disc brake with the 4/6 suspension. When I asked for the 4/6 the guy told me a c-notch was required if lowering the rear 6 inches or more. I thought I could lower 6 and not need it, unless I went lower. Can someone please clarify this for me. Thanks
Moderator
![]() Join Date: May 2007
Re: 4/6 drop???
You will have about 1" of clearance with a 6" rear drop...a c-notch is recommended, but not required. I have a 6.5" drop in the back and need a c-notch as I bottom out fairly easy. CPP does not sell 6" rear drop springs to my knowledge. I am running 5" CPP rear springs with a 1.5" drop block.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#4 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 4/6 drop???
Grandpa in the rustmobile...
Re: 4/6 drop???
ece=great customer service
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: 4/6 drop???
NO C-NOTCH NEEDED WITH A 6 INCH SPRING....i AGREE ece WAY BETTER WHICH IS WHAT i HAVE...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
![]() Join Date: Apr 2010
Re: 4/6 drop???
Hope everything works out with cpp. If not, you will def wish you would have went ece.
