Old 03-19-2003, 12:56 AM   #1
68speedalert
Semi-Senior Member
68speedalert's Avatar
Putin fenders on bed
Any one have a suggestion on what, if anything, to put between the rear fenders and the bedsides on a 72 short-step?
Steve
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 03-19-2003, 01:12 AM   #2
68LSS1
68LSS1's Avatar
I use a tape that is a little thicker than duct tape, it has a brownish tint but you can see through it and its made from teflon.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 03-19-2003, 01:18 AM   #3
68speedalert
Semi-Senior Member
what is it normally used for &/or where can I get it. I like the sound of teflon in it.
Steve
Old 03-19-2003, 01:50 AM   #4
68LSS1
68LSS1's Avatar
I use it on various leading edge items on aircraft. Flap hinge covers, antennae's, wing tip light lenses, etc. I'll check around to see where some can be had--maybe I can hook you up with a roll.
'68 Short Step
Old 03-19-2003, 08:41 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
You mean fender welting? Chevyduty has the original type and it's cheap. I just used it last year and im very happy with it.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 03-19-2003, 02:01 PM   #6
teeitup
Just like to part out trucks!!
teeitup's Avatar
I put the same stuff on my 67 from chevy duty, it turned out great.
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 03-19-2003, 08:21 PM   #7
JimKshortstep4x4
Talking
I used the fender welting from Chevy Duty also. To make sure that there were no water leaks I used a sealant. I glued the welting to the fender, burned holes through the welting with a soldering iron for the mounting screws, and applied sealant to the welting before installing.
I am a little afraid that the sealant will act like adhesive, so I hope to never have to remove the fenders. Anyway, I don't have any leaks!
Jim
Old 03-20-2003, 02:34 PM   #8
68speedalert
Semi-Senior Member
thanks guys
I assume that that is the welt on older trucks that has the bead that is exposed? If so, do you paint your fenders separate from the bedside?
Steve
Old 03-20-2003, 02:51 PM   #9
JimKshortstep4x4
Talking
The welting that I used has beading and I painted my fenders separately before mounting them.
The welting is black and it is not very visable unless you look for it.
(My truck is a dark green).
Jim
Old 03-21-2003, 09:01 AM   #10
bobs409
bobs409's Avatar
Yeh, it looks like black leather (probably just vinyl) and it has a plastic tube like thing in it to produce a bead. (hows that for an explination? LOL) Ever see an old VW beetle? They used fender welting too but it was rubber.
I painted my fenders off the truck and then installed with 2 bolts loosely to hold the fender in place. I then started at one end by putting the welting in place and poking a hole, then loosely installing that bolt. Then just procede along doing each one. Once it's all in place, and looks good, snug up all the bolts and admire the fabulous clean look it produces. It's one of those little details that really makes a good impression.
BTW, I like Jimshortsteps idea of attaching the welt to the fender and burning in the bolt holes. I might have tried that if I had know of that method!
Bob
