Old 03-08-2011, 08:29 PM   #1
Sojo
Smile 53 Pickup window conversion
I'm building a 53 pickup and would like to eliminate the vent windows. Does anyone know of a conversion kit for this?? thanks....Sojo
Sojo is offline   Reply With Quote
Old 03-08-2011, 08:46 PM   #2
Maximus
Maximus's Avatar
Re: 53 Pickup window conversion
I am a 'Task Force' guy but if im not mistaken the 51-55 AD trucks only had the vent window because they removed the vent in the cab...
I think you can get a window setup from a 47-50 truck as they came stock without a vent window...
someone correct me if im wrong. ... but look at the earlier trucks...
Maximus is offline   Reply With Quote
Old 03-08-2011, 08:53 PM   #3
Maximus
Maximus's Avatar
Here is the window frame for the 47-50 trucks
from the sponsor, ClassicParts.com
I might have been off a year, 47-50.
http://www.classicparts.com/Door-Glass/products/58/
Old 03-08-2011, 09:34 PM   #4
Sojo
Thanks for the reply, but I think that the pre-53 trucks (no vent window) have a window glass that has a medal "molding" around it which requires a larger opening between the inner and outer skins of the door. I'm hoping that someone makes a kit that includes glass, mounting hardware and power window motion. I once saw one for a 65 but don't remember who had it. Scott
Old 03-08-2011, 10:46 PM   #5
Atomsplitter
Atomsplitter's Avatar
Here's the Custom Classic Truck link describing the procedure and there is a list with part numbers on page 3.
http://customclassictrucks.automotiv...ion/index.html
Atomsplitter is offline   Reply With Quote
Old 03-08-2011, 11:57 PM   #6
Maximus
Maximus's Avatar
If your truck is not yet painted, and you didn't want to tackle the swap, you could always track down a set of doors off of a early truck..
not always the most convenient solution but it would definitely do the trick...
Old 03-10-2011, 09:27 PM   #7
WIDESIDE72
WIDESIDE72's Avatar
I looked into doing a door switch on my 55 1st series. My dad has a 47 GMC with ne piece glass in the doors. If you switch door, you will also have issues with the door latches as the door with 1 pc glass had the twist type door handles and the 2 piece had push button handles.
WIDESIDE72 is offline   Reply With Quote
