Old 03-08-2011, 08:39 PM   #1
daverod
SSN 706
daverod's Avatar
rear end with disks
I've got a 52 with a s10 frame. I like the idea of disks in the back. I'm thinking a zr2 might be to wide. What other options are there?
daverod is offline   Reply With Quote
Old 03-08-2011, 08:57 PM   #2
bowat6969
bowat6969's Avatar
Re: rear end with disks
You can look at the Explorer or Mountaineer 1995 on up. They have factory disk brakes and I'm not totally sure of the width measurement but may be close to what the S-10 is. Hope this helps!!
Thanks,
bowat6969 is offline   Reply With Quote
Old 03-08-2011, 09:25 PM   #3
BlueJeep
BlueJeep's Avatar
ZR2 is the perfect width.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-08-2011, 09:37 PM   #4
GRIMSS
GRIMSS's Avatar
I had a 98 2wd jimmy with rear disk brakes.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 03-08-2011, 10:34 PM   #5
Thadious
I'm just rebuilding a rear disk from a 2000 S10 Jimmy 4x4 with 3.73s and posi and from the looks of the numbers, I'll be using it with 17"x8" rims with 3 1/2" backspacing (which is stock apparantly for 2wd S10s, 4x4 are supposedly 4 1/4"- 4 1/2").
Cheers,
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 03-09-2011, 08:42 AM   #6
72Mountaineer
72Mountaineer's Avatar
A friend has a rearend from a '84 Camaro with rear discs in his '53, fits great.
72Mountaineer is offline   Reply With Quote
Old 03-09-2011, 02:13 PM   #7
01spirit750
1979 Cadillac Seville has the heavy duty 10 bolt rear end differential and disc brakes.
01spirit750 is offline   Reply With Quote
Old 03-09-2011, 02:56 PM   #8
blitz'd
vintage car junkie
blitz'd's Avatar
Cheers,
Ted.
This is what I have in my truck. My wheels are 9.5" wide with a negative offset. I will need either a .5 spacer or tub the bed a little.
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 03-09-2011, 06:57 PM   #9
OldJimmy57
The Ford Explorer mentioned above is probably your best bet. From 95-01 I think or close to that. They came with a beefed up 8.8 with limited slip, disc brakes, 3:73 gears (have 4:10 and 3:42 available as well i think), sway bars and e-brake cables. They are 59.5" wide factory and if you do the short side axle conversion then you can narrow it 2 more inches and not have to send your axle off to have it narrowed. Also the explorer rearend comes with the larger 3.25 axles tubes and the 31 spline axles. It is stronger then the 9" with 28 spline axles and also beefier then the dana units
http://67-72chevytrucks.com/vboard/showthread.php3?t=145432
OldJimmy57 is offline   Reply With Quote
Old 03-09-2011, 08:37 PM   #10
mazer78
i just picked up a zr2 rear, and to be sure that it would work, i rolled it under the truck, and mounted some 235/70r15s on 15x7 roller wheels that i keep around for mockup and whatnot. it seems to fit fine, although a wider tire would definetly not work with the standard backspace of the wheels.
mazer78 is offline   Reply With Quote
Old 03-09-2011, 09:13 PM   #11
daverod
SSN 706
daverod's Avatar
If you narrow the axle do you have to tub the bed? I don't want to have to tub the bed. What's the short side axle conversion? I'll have to price one.
Old 03-09-2011, 09:15 PM   #12
daverod
SSN 706
daverod's Avatar
I kinda like the Zr2 idea but I would like to have the option of running wider tires. I think 8" wide is about the max.
Old 03-09-2011, 10:15 PM   #13
RootBeer 6117
RootBeer 6117's Avatar
I am using a ZR2 rear axle with 15x8 rallyes from wheel vintiques.Right now I have 265-70s I have no clearance problems with it. I picked the tires up used cheap to see how they fit I had 255-70 in the shed.
I will probably try a shorter tire these are a little to tall. the frame is an 89 S10 setting at stock height for now. If I went any wider or had a narrower rear end I would have to use wheel tubs in the bed.
RootBeer 6117 is offline   Reply With Quote
