Franken Fender
Had a rust free 69 fender that was smashed badly in front, and a very rusty 71 that was good on top. So I drilled out the spot welds on both fenders, cut them apart, and welded them together. I think this might work!
Gary ![]() |
Re: Franken Fender
Gary, its just like a large patch panel (only it fits) check it with a straight edge across the seam if its inline your good to go! cheers, Pat
Re: Franken Fender
The 2 pieces fit together very well, some of the spot welds were even in the same place. I clamped them together, then cut them both at the same time. I put a straight edge on the weld, and it seems to have pulled in a little, so some bondo ought to fix it up!
